Common problem/weak point on the speedometer gauge?
Old Oct 6, 2017 | 04:27 PM
OldFaithful's Avatar
Talking Common problem/weak point on the speedometer gauge?
My speedometer/odometer stopped working a few months ago after reading a zillion forum posts and running some tests I now know it is the gauge itself. I'm driving a 1992 4Runner 22re 4x4 manual. So far it looks like the only fix is to buy an entire cluster which will run about $100-200 on eBay. I'm wondering if these speedometers have a common weakness or something I can test on the gauge that I can fix cheaply. Plus I would rather not dispose of my whole cluster for something that could be fixed.
For example, I had a BMW E36 and the climate control stopped working - apparently it was a really common problem caused by a failing capacitor. So it took about 95 cents and 20 minutes to get it working again. Can't seem to find anything similar for this 22RE speedometer - ideas?
Old Oct 7, 2017 | 07:55 PM
scope103's Avatar
Electronic or cable? I was able to direct-test my electronic speedometer with a frequency generator replacing VSS1 (This confirmed that I needed a new VSS1.)
Everyone has a frequency generator, don't they?
Old Oct 7, 2017 | 08:14 PM
Electronic. Pretty sure something happened to the speedometer circuitboard. Check out the black stuff on the top:
Judging by the pattern of the discoloration I got a circuitboard pen and tried a fix. Didn't work so tomorrow I'm going to try replacing the capacitor on the opposite side of the original black buildup above.
Old Oct 9, 2017 | 08:06 AM
Melrose 4r's Avatar
5 Year Member
What freq and amplitude did you use?
You can download freq gen apps for smart phones.
Old Oct 9, 2017 | 08:56 AM
scope103's Avatar
True. https://www.edn.com/electronics-blog...gnal-Generator
"Smart" phone. Pfft!
You'd need to be able to drive 5volts with a more-or-less square wave. I doubt a smart phone could swing that much through a head-phone jack without some amplification.
But if you want to try it, 111.1 Hz => 100mph on my rig.
