Brake light on?
Old Oct 10, 2017 | 07:31 AM
yota tay's Avatar
Brake light on?
What would cause the light to be on if the reservoir is full? It mostly comes on when going up a hill or making a hard turn. Anybody know where I should start checking? Also the connector seems snug.
Old Oct 10, 2017 | 08:30 AM
scope103's Avatar
The Brake light also comes on with the parking brake. It can also come on if the alternator stops working.
But based on your stated symptoms (hill, hard turns) I would guess you have a water(fluid?)-logged float in the brake fluid reservoir, or a bent hangar. Just remove the cap and gently press down on the float. I can't tell you how many mm it SHOULD move before illuminating the light, but it should be at least the spacing between the "full" and "add" lines. If it's only a mm or 2, there's your problem.
Old Oct 10, 2017 | 08:43 AM
yota tay's Avatar
Ok will check that. Thanks.
Old Oct 10, 2017 | 09:37 AM
Nervo19's Avatar
On my son's 2000 Tacoma the brake light kept coming on. I greased the parking brake cable and it fixed it. Five minute repair.
Old Oct 10, 2017 | 01:45 PM
yota tay's Avatar
Where exactly did you grease it? Thanks.
Old Oct 11, 2017 | 06:15 AM
89fourrunner's Avatar
Whenever I release the parking brake I always have to give the handle a little shimmy and shake to get the light to go out!
Old Oct 11, 2017 | 11:21 AM
Nervo19's Avatar
If you crawl under it will be obvious. There's a brake cable running to the rear. Take your bottle of spray grease when you climb under and it takes a minute.
Old Oct 11, 2017 | 01:43 PM
RAD4Runner's Avatar
T ...But based on your stated symptoms (hill, hard turns) I would guess you have a water(fluid?)-logged float in the brake fluid reservoir, or a bent hangar. Just remove the cap and gently press down on the float. I can't tell you how many mm it SHOULD move before illuminating the light, but it should be at least the spacing between the "full" and "add" lines. If it's only a mm or 2, there's your problem.
+1
most likely this ^^^
But also check your e-brake sensing switch, in case it is just so slightly out of adjustment.
Old Oct 11, 2017 | 02:40 PM
scope103's Avatar
... But also check your e-brake sensing switch, in case it is just so slightly out of adjustment.
As 89fourrunner says, "testing" the e-brake sensing switch (at least on the first go) is pretty easy. No need to climb under the truck until you determine it's the culprit.
What if shaking the parking brake lever makes the light go out? What do you do? All answers are found in The Good Book: http://web.archive.org/web/201102052.../6combinat.pdf
