Head gasket
Old Oct 24, 2017 | 03:22 AM
Jdeaton0's Avatar
Head gasket
Ok, I got this 94 3.0 Toyota pickup.. I got it in a no start condition.. the guy said it run hot so I'm thinking head gasket but should run.. I do the usual checks drain tank replace fuel filter. When I got to the plugs I found my problem.. there is a picture of what they look like attached.. they smell like coolant.. old rusted up coolant. Head gasket right? This guy said it was steaming but I bet it was billowing smoke!
Old Oct 24, 2017 | 02:23 PM
Jdeaton0's Avatar
Anybody have an idea if it's more than likely my head gasket?
Old Oct 24, 2017 | 02:32 PM
scope103's Avatar
Originally Posted by Jdeaton0
... I do the usual checks ...
What are those?
Did you check compression?
Before I did that, I might leave the plugs out (which you should do for a complete compression test) and crank. If water sprays out of any of the cylinders, you either have a blowm head gasket or cracked head/block. And you'll only know about the head and block after you remove the head anyway.
Old Oct 24, 2017 | 03:01 PM
millball's Avatar
That stuff didn't just lay in there for a few days. I expect you'll find the cylinder walls rust pitted.
Old Oct 24, 2017 | 05:59 PM
mikesnyhere's Avatar
I agree with Millball that sucker sat awhile . and about the cylinder too , people just dont know to drain coolant ,and pull plugs ,and put some light oil in if its gonna sit ... then turn it by hand once in awhile .
Old Oct 25, 2017 | 01:10 AM
Jdeaton0's Avatar
That's the funny thing, it only sat a month.. I know the truck. It was up and running at the most 2 months ago..
Old Oct 25, 2017 | 01:26 PM
Mclaws89's Avatar
Running but how well? Is it possible that one cylinder hasnt fired in a while? Do all the plugs look like this?
Old Oct 25, 2017 | 02:26 PM
Jdeaton0's Avatar
Yes they all look like this..
Old Oct 25, 2017 | 02:30 PM
Jdeaton0's Avatar
I put new plugs in and still won't start.. getting gas, the plugs are firing but may be weak.. it won't hit off starting fluid either.. it try to hit a little but never fires up. No codes.. distributor?
Old Oct 25, 2017 | 06:20 PM
scope103's Avatar
Originally Posted by scope103
... Did you check compression? ...
Even a "weak" spark will fire a compressed gasoline-air mixture. But if not compressed, not enough combustion to run.
Old Oct 25, 2017 | 06:29 PM
Mclaws89's Avatar
With that much gunk in the plug, your head gaskets have got to be shot. Maybe low compression like scope says?
Old Oct 25, 2017 | 06:48 PM
Jdeaton0's Avatar
I'll check compression tomorrow after work.. then if that's bad I guess it's teardown time.. yay.. I've just never seen a head gasket being blown keep the vehicle from starting..
Old Oct 25, 2017 | 06:51 PM
Jdeaton0's Avatar
I mean I know it's possible but me personally most of the time it still cranks.. but I guess it's which way it blows and how bad. I could probably take my radiator cap off and see if I got air coming out while I'm turning it over..
Old Oct 25, 2017 | 07:06 PM
millball's Avatar
All plugs look like that???
If I was a bettin' man, I'd bet that that engine will give no more service without complete overhaul, top end and bottom. Good luck!!
Old Oct 26, 2017 | 03:05 AM
Jdeaton0's Avatar
Yep.. that's what I'm thinking.. idk how it would've happened.. it run hot i know that.. . It turns over seemingly normally .. not fast or anything.. maybe the block is cracked?
Think I should take oil pan off and inspect?
Well I got to check compression first..
