Why is pumping gas a chore?
Old Oct 3, 2017 | 09:55 AM
personality's Avatar
I have a '95 base model pickup, and it is a pain in the ass to fill the tank. The gas nozzle needs to be held in the filler the whole time or it will eject itself. The more annoying part is that the nozzle will auto shut off a bunch of times randomly way before the tank is full.
Is this just me, or does everyone have this problem? I guess the rubber bellow seals on the nozzles that are supposed to prevent gas vapors from escaping are the culprit? I'm in California, if that makes a difference?
Old Oct 3, 2017 | 10:33 AM
old87yota's Avatar
I have never had that problem... although I live in Oregon, where we don't pump our own gas.
The gas station attendants never seem to have a problem keeping the nozzle in the fuel filler and the nozzle only shuts off when the tank is full.
I have a 1987 truck, but they should be about the same.
Does this happen at other gas stations?
Can you see any damage to the filler neck?
Maybe California gas pumps are different than the rest of the US.
Old Oct 3, 2017 | 01:52 PM
L5wolvesf's Avatar
When I fill mine the nozzle will click off if it isn't in at the right angle. I believe it is that the fuel sloshes back if the fuel isn't flowing completely unobstructed.
Old Oct 3, 2017 | 02:08 PM
Yes, every station I go to. It's like the nozzles aren't long enough to stay in the filler.
Maybe it is a CA thing? All the pumps have rubber bellows (as seen in the photo below) around them that are there to prevent vapor release. I thought these were nation wide though, and they don't pose a problem with my jeep or the gf's civic. It has been a while since I pumped gas in any other state.
No obvious damage to the filler or that side of the truck for that matter
Old Oct 3, 2017 | 02:40 PM
ksti's Avatar
Actually the bellows on Calif. pumps were discontinued in 2012
www.cnn.com/2012/05/10/politics/epa-gas-pump-handles/index.html
But alas, Its still a pain as the nozzle end seems to be a little short and not angled enough for our older rigs.
Old Oct 4, 2017 | 06:06 AM
Terrys87's Avatar
I bought a truck and someone had a garden hose stuck in the fill tube. Apparently some one was trying to steal the fuel out of it. I have dealt with the gas nozzles that you are talking about. I would pull the fuel tube and see it is jammed up with something.
Old Oct 4, 2017 | 08:15 AM
Brock Lee's Avatar
It's not just you! For some reason I thought I was the only one. I have a 94 Hilux 4x4 and when I first got the truck I went to the gas station. After setting it up and getting the gas flowing the CURSED NOZZLE JUMPED RIGHT OUT and fell to the ground! I felt like a complete idiot! The angle that the nozzle has to be in order to pump gas into the tank is weird. Now I always put a little weight on the nozzle and I never leave it unattended when fueling up. It's irritating! I think it's a flaw in the design.
Old Oct 4, 2017 | 12:16 PM
RAD4Runner's Avatar
Similar/related issue on mine. I have to hold the nozzle at a steeper angle, such that the mentioned rubber seal is not even flush with the base of the opening (not sealing). I just hold it that way but I move as far as possible and face away so I don't inhale the fumes.
There were very few places I drove through where there is no such vapor-return seal and I could leave the nozzle latched. However, others also pop shut when I let go of the nozzle. I think those places are also outside CA.
Old Oct 4, 2017 | 12:52 PM
ksti's Avatar
Uh Oh, I have always inhaled the fumes.
Old Oct 4, 2017 | 01:26 PM
wyoming9's Avatar
Red face
I fuel so many different vehicles anymore I just correct to make things work
I always fuel at the slowest speed .
Old Oct 4, 2017 | 02:57 PM
highonpottery's Avatar
Yep. My 93 pickup is the only vehicle in my fleet that has issues when filling it up. Can't use the trigger holder thingy for auto-fill because it always clicks off after like 2 seconds and shuts off. It's the ONLY vehicle I've ever filled up that has had the whole gas dispenser gun fall out of the truck when the click happened, which was freaky - it also put about 1/3 gallon of gas on the ground - thus I stand there and baby it. Heck, even my 75 Hilux has no issue at the gas station, go figure.
Old Oct 5, 2017 | 07:01 AM
ewong's Avatar
I've always had to "hold" the nozzle at a "steep" angle to get it to fill and not click off.
BTW - I've also had this issue on a Volvo 240 wagon of a similar era (late 1980s)
I think its way the filler neck is designed wonky.
But fixing it, isn't worth the effort.
Old Oct 5, 2017 | 10:40 PM
RAD4Runner's Avatar
LOLOL!
I think its way the filler neck is designed wonky...
Probably this.
So I am not alone after all... LOL!
Old Oct 6, 2017 | 04:35 PM
yota tay's Avatar
Same here. I have no problems filling up, but the gas nozzle will fall out if I'm not holding it. Or it will stay in but fall from any little disturbance.
Old Oct 6, 2017 | 05:10 PM
L5wolvesf's Avatar
I don't have to hold it in at a certain angle. If I shove the nozzle in the hole sufficiently it stays in until the full load is delivered.
I wondering if I am on the right site - everyone is talking about the angle of their nozzles.
Old Oct 6, 2017 | 06:22 PM
ksti's Avatar
Yes, the gas nozzle with the prophylactic boot on it in the short movie that shown above.
Old Oct 7, 2017 | 06:30 AM
L5wolvesf's Avatar
Good to know everyone is practicing safe pumping".
Old Oct 7, 2017 | 12:30 PM
wyoming9's Avatar
Red face
I need a cute girl to ride along and pump gas and wash the windows check the air in the tires
Old Oct 15, 2017 | 07:34 PM
shadowstewie's Avatar
Same issue here in California. Haven't tried other states yet.
Have to hold it with firm pressure or it will shut off.
Old Oct 15, 2017 | 08:08 PM
Punchy's Avatar
My 92EC 4x4 also drops out, Even with the short rubber on the nozzle., My ex 924R did not.
The 4R angle is more vertical then the PU.
