1990 22re ignition coil question
Old Oct 5, 2017 | 05:48 PM
shafner30's Avatar
So I got a question about my ignition coil this is not my coil but it’s the same style it’s a CAN ignition coil how can you tell if this is not running right or bad ? when it goes bad does it not work anymore or would it decrease in voltage and what are the symptoms
thanks
Old Oct 5, 2017 | 11:48 PM
wyoming9's Avatar
Red face
You can measure the Primary and secondary resistance of the coil .
If there is a good way to check the igniter I don`t recall ever doing it
