Cab/cargo divider ideas for '86 4runner?
Hey guys. I'm going to be using my '86 4runner to move roughly halfway across the country. (I've had a shop replace roughly half the truck, so it should, knock on wood, be mechanically sound.) But I'm worried about not having a divider between the cab and all of the boxes and other stuff I'll be hauling in the back in case I have to stop short or I roll over. I've seen guys bolt metal dividers on the roll bar, but has anyone installed a cargo net behind the front seats? I'm looking for something like this. I don't have access to too many tools, so the lowest-tech effective solution would be the best for me. Any thoughts? Thanks, guys.
...I've seen guys bolt metal dividers on the roll bar, but has anyone installed a cargo net behind the front seats?
IF behind the rear seat, then you can readily tie THAT cargo net to the roll-bar and the cargo tie down near the front base of the roll-bar (on the rear wheel-well with low-tech, old-fashioned rope and knots.
If behind front seats, you may need to add tie-UP points. You can use rear corners of front seat rail/mount for tie-DOWN points.
Thanks for the advice! Do you have any recommendations for creating tie-up points? They would have to be on the B pillars, I guess. Would you weld, or would you drill and add a bolt? I'd rather not weld. Would you happen to have any DIY examples?
Take the fiberglas camper shell/cap mounting bolts out, find correct combination of bushings/spacers and bolt-on D-rings.
Take off the rear seat bottoms (better if you're filling the back with cargo, anyway). Use the four mounting screws to mount D-Rings.
No cutting, drilling, tapping nor welding,
RAD4Runner's method would work fine for what it sounds like you want to do.
I had these in my 81 Trekker
http://www.discountramps.com/tie_down_rails/p/TRAK8/
when i stripped that truck they found their way into my 4Runner
by https://www.flickr.com/photos/42814812@N06/, on Flickr
I have a cargo net that can tie down to the floor or sides to hold stuff down or use bungee cords or what ever
not exactly low tech but works for me.
I like the cargo net that you found
dropzone—I think RAD4runner's system will be the best for what I'm after, just because it'll give me close to full coverage, though I like those rails a lot. Thanks for letting me know about them. I might want to install them just for the sake of versatility later on, and maybe as extra support for a net, six points of contact being better than four.
I'm also really excited to see the tool box you've got in yours. I was thinking of doing something similar. Before I bought the 4runner, I had planned to get a pickup, throw a Softopper on it, and use a box like that without the overhangs. But the 4runner showed up at the right time, and I definitely don't regret buying it instead.
