Exhaust popping/backfiring after desmog during enginebraking
Anyone else get this? On engine braking/deceleration there is a bit of an obnoxious continuous popping/backfiring that comes from the exhaust. I have a muffler and catalytic converter of course but have eliminated most other emissions equipment. I have been thinking that it's perhaps a result of removing the air injection system which takes fresh air from the intake and sends it into the exhaust manifold. If I can determine exactly what emissions equipment to add back into the equation to eliminate this I would do it.
Yes, that is one of the symptoms of a non-working PAIR system. http://www.cygnusx1.net/Media/Supra/...taTech/h65.pdf It can also be caused by a defective throttle damper (dashpot).
The only way to assure good vehicle operation is put back all of the equipment you removed. Unless, of course, you're a much better automotive designer than the engineers who built your truck.
Anyway, If anyone else has any thoughts on the slight backfiring on deceleration, let me know! Are there any items you added back into your setup to control it? Or did you decide it wasn't a big deal to you?
The following users liked this post:
wadester33 (07-18-2019)
