PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Hello, new member Dan. Can't seem find a part for a 13.5 gallon tank
  2. 1990 Pickup Surging
  3. 22RE: What are these Connections??? (Post-Head Gasket Replacement)
  4. 89 sr5 v6 oil question
  5. 91 4Runner 3.0 Engine Tick
  6. Need Help With 22re Fuel Pressure Reg. 94 Pickup
  7. 95 4runner power brake booster with or without abs?
  8. 95 4Runner 3.0 No Start
  9. Fuel indicator wiring
  10. Which injectors to buy
  11. '91SR5 V6 4X4 - low end miss/rough idle - CEL code 25
  12. leak down test on 91 4runner
  13. sr5 cluster swap question
  14. Transmission Woes - Advice Needed
  15. 89 4x4 front seal question
  16. truck will not turn over
  17. Turbo Instrument to Cluster to Non-Turbo
  18. upgrade brakes system = pumping pedal
  19. 1994 4runner 3.0 cranks and dies
  20. 1986 4runner t-case
  21. Why Is This Better Yet Cheaper?
  22. 22r 13 mpg fouling plugs
  23. Shocks
  24. Swapping Questions and Help!
  25. bucket seats
  26. Extra sender in 22RE thermostat housing
  27. 1994 Pickup Surging Idle
  28. Timing marks move?
  29. 86 4Runner Digital Cluster SWAP; How to/ HELP!!!
  30. Potential Buy 93 v6 needing gas tank etc
  31. how large a tire should I be using?
  32. start up idle troubles
  33. A/c tube
  34. 94 4Runner Clunk In Rear End
  35. HELP needed badly...wiring harness
  36. Need advice on timing chain
  37. Bumper swap
  38. A Little Engine Bay Detail on a Saturday
  39. Gas tank, differrent lines...
  40. 3vze timing belt doesn't match gear marks
  41. Motor skip 22R
  42. anyone ever had this noise
  43. 22re No start/ click only problem
  44. Another 22RE Bouncing Idle Problem
  45. 3VZ-E VAF help!
  46. 1st gen 4runner interior part interchangeability
  47. fuel filter
  48. 1988 4 runner motor
  49. 1989 3.0 sat long time now acceleration issues
  50. Replacing a rear U-joint, w/pics
  51. motor mounts
  52. Hood flap
  53. Muffler/Tail Pipe replacement
  54. Upgrade to 4 point seatbelt?
  55. 3vze head gasket rebuild snafu
  56. interchangeable parts?
  57. Leaf Springs
  58. driving on a broken leaf spring?
  59. Speedometer issues? Anyone use a gps speed sender?
  60. help - 92 3.0 losing minimal coolant
  61. '89 4x4 exhaust question
  62. Newbie: Uhaul Toyota one ton dually box truck help pre- purchase
  63. relocating transfer case oil cooler
  64. Power Loss/Pressurized gas tank
  65. PAIR valve removal pros/cons 22RE
  66. check engine light code 25
  67. vacuum line? identification
  68. Rear power window
  69. Fairly new toyota enthusiast
  70. undercarriage rust
  71. Squealing noise
  72. Truck is skipping
  73. Harmonic Balancer
  74. Flamethrower Tan Injectors: Review
  75. Strange electrical issue after body lift
  76. 22re hard starts
  77. supercharged 3vze
  78. Oil leak
  79. The rebuild continues...89 4Runner 3.0 V6
  80. LCE 22re Exhaust
  81. My new-old 1993 SR5 4x4
  82. CV Axle Replacement Help
  83. Back in the yota game
  84. Covering bare metal behind seat
  85. '93 AFM internals not working in new AFM
  86. Complete rebuild '95 22re now it won't start.
  87. 1993 SR5 4x4...Switch next to dash dimmer...What is it?
  88. 3vz Power Steering, Out of Ideas.
  89. gearing
  90. 22R rough when cold, better when warm
  91. tire size
  92. Dually axle
  93. Basic manual windows
  94. surging idle troubles
  95. 22R Carb issues after Rebuild
  96. 22re WOT issue.
  97. Two shocks broken in less than 6 months? what the...?
  98. There's something wrong with my Yota.
  99. How will a Cam Effect Fuel Economy???
  100. 22RE - How Much Oil Do You Burn???
  101. surf body lift..
  102. B-piller question
  103. dc diesel wanted
  104. 1993: Drain-Fill Plug Washers Diff/Manual Trans/Transfer Case PNs
  105. R12 or 134a?
  106. Power Steering Swap
  107. rear sag
  108. 1992 Toy P/U 4Runner upper contol arm replacement
  109. Top two bell housing bolts
  110. Swapped tranny output and TC input seals, am I screwed?
  111. Ghost in the Machine
  112. Wiper fuse keeps blowing/tailgate window
  113. spark plug hard to back out
  114. Wing vs Solid Glass door question
  115. A/C belt saga
  116. shocks
  117. 22R Carb - Throttle plate linkage/action
  118. Truck not starting HELP
  119. steering column swap
  120. Help!
  121. '91 3.0 Broken Cooling Fan
  122. please help
  123. Low Air Volume through Dashboard Vents - Evaporator
  124. Just installed my new flamethower inj. now truck is smoking
  125. How much of the body parts are interchangeable on 1987 & 1985 Toyota trucks?
  126. 94 PU a/c condensation excessive under dash
  127. Timing belt kit help
  128. Quick 3VZE Fan Clutch Question
  129. Am I having cold start injector problems?
  130. PAIR Valve, Oil Filter, amnd Sluggish Fuel Injection for 1994 Toyota Pickup
  131. Radiator fluid leak in my engine?
  132. Loss of ignition and other things.
  133. Barn find 89 pickup
  134. will a older doug thorley header fit?
  135. Building a spare/replacement engine?
  136. what is a good performance cam for a 3vze
  137. 87 4Runner starts then dies...
  138. heater fan..
  139. 22re hunting & high idle after throttle body cleaning
  140. 1st 4x4 common problems or gotchas 87 Toyota 4x4
  141. Rear passenger window vertical guide repair parts?
  142. 1990 Pickup Power Door Problems
  143. 94' 22RE 4x4 Rear U-Joint Replacement?
  144. vacuum lines what's really needed
  145. Cam sprocket backwards?
  146. Towing with an 89 pickup 22re?
  147. Weather Strip
  148. Missing at Idle only
  149. yet another a43d issue
  150. 91 v6 distributor cap and rotor heat damage
  151. No power problem!
  152. 87 yota weber water choke
  153. ct20 to t3 swap help?
  154. 89 toy pu tps sensor adjustment
  155. 1990 toyota pickup
  156. torque converter install
  157. 4runner removal top question
  158. Low Fuel Light
  159. 94 22re distributor squeak
  160. Lower control arm angles
  161. does valve cover come off for timing cover
  162. 1994 3vze hard start
  163. Dual AC Condenser?
  164. changing motor mounts best way/place to jack up motor
  165. 91 swap out 3.0 to 3.4
  166. 1993 3vze will not accelerate
  167. Need some help
  168. Throwing Caution To The Wind
  169. Valve stem bent
  170. 15 inch vs 16 inch
  171. Brake Problems
  172. Installing tach wire for factory SR5 dash
  173. 90 radio antenna
  174. Grinding Sound in '87 4Runner
  175. Clutch Fork Ball Stud Squeaking
  176. 3.0 ecu
  177. Idler arm problems please help
  178. Fresh off rebuild, no spark?!?!?!?!
  179. passenger side window does not work with master switch
  180. It runs better in the rain?
  181. 3.0 won't rev up
  182. 3.0 engine swap
  183. factory fuel tank skidplate help
  184. max tire size
  185. cluster swap:
  186. help with dual timing chain
  187. Passenger Power Window Problem
  188. 91 pick up brush guard
  189. 4x4 front differential vacuum line hoses to short after lift
  190. OME 2in lift on 1993 4runner
  191. engine
  192. flamethrower injector review
  193. New Engine. So sad.
  194. Gasket for a rear window?
  195. Cluster board switch
  196. Help! Unique rear-window problem
  197. 22r coolant pipe.
  198. 86 toyota 4x4 auto trans issue
  199. Just realized my rear wheels are misaligned on the 4runner.
  200. Hellwig helper springs
  201. Seek suggestions for front end body work / electrical
  202. just fitted flamethrower injectors
  203. B&M Transmission Oil Cooler Install
  204. idle problems, 1990 4runner
  205. Replacing the power steering pump/hoses
  206. 95 Toyota Pickup clicks but won't start
  207. Having trouble starting my 87 help
  208. All pro flatbed kit
  209. Shovel and other gear mounts I'm a 1990 4runner
  210. 88 22re 4runner runs hot at highway speeds
  211. axle and sensor question????
  212. Bad transmission?
  213. I dun screwed up, pinion nut tightening.
  214. 86 22re WEIRD sound
  215. Air intake
  216. E-Fan for 5 years -- Observations
  217. 89' Pickup Leaf Spring Clanging
  218. 1986 22r, engine problems.
  219. Pompatus's 1994 4runner project
  220. runs off ether
  221. 89 3vze in a 92 4runner
  222. '93 V6 4Runner front end on '94 22RE Truck
  223. Sloppy steering, VIDEO of problem
  224. injectors not firing
  225. 89 pickup won't rev past 1500rpm in 4x4
  226. Carb Issue
  227. CV axle replacement
  228. issues with 22re idle, violent misfires, and backfiring.
  229. Two questions - getting hot and can't go fast
  230. What brand head bolts other tham OEM?
  231. speedometer stuck in my 91 4runner
  232. EFI Fuse Blows when engaging 4 wheel drive
  233. 80 AC components fit 87 4Runner?
  234. 3.4 swap hesitation - Possible TPS problem
  235. Replace aal with shakles
  236. DIY 4Runner Bikini Top
  237. Help with bigger brake upgrade
  238. 1" body lift hardware length
  239. Difference in frame dimensions "4cyl vs V6
  240. 89 Camper v6 exhaust manifolds
  241. Beater Rig
  242. 87 22r Timing issue
  243. Is it possible to add power steering...
  244. Muffler thread
  245. How do you adjust the hvac controls?
  246. newbie over here.
  247. Will not stay in o/d
  248. 87 22r reaching 210 degrees
  249. Marlin Crawler Shifter Bushings = AWESOME!
  250. 1st post on here, new 1992 pickup owner
