Hood flap
Old Sep 4, 2014 | 11:42 AM
Jake28296's Avatar
Hood flap
My hood flaps up and down when I get past about 35 mph is there a way to fix it? Just curious couldn't find anything on it
Old Sep 4, 2014 | 11:54 AM
JasonYota's Avatar
Is it latching shut all the way?
Old Sep 4, 2014 | 11:56 AM
Jake28296's Avatar
Yes it shuts all the way And I still push it down 2 or 3 times after I get it down as far as it goes and it still does it
Old Sep 4, 2014 | 12:00 PM
JasonYota's Avatar
Is there any way to move what it latches to? Haven't looked at mine in a while
Old Sep 4, 2014 | 12:36 PM
Jake28296's Avatar
Don't think so I've tried cleaning it and doing other stuff but never worked
Old Sep 4, 2014 | 02:40 PM
Sturmcrow's Avatar
Hoods have two latching points. One is the safety catch that keeps it from flopping open all the way. The other is the final catch, which is what you release from inside the cab. My guess is that the final catch is not catching. If you look at the corners of the open hood you wiill see some plastic screw things. Screw those in or out until your hood works properly.
Alternatively, your in-cab hood release could be broken or the cable could be sticking. Look into that.
Old Sep 4, 2014 | 03:35 PM
highonpottery's Avatar
sounds like those rubber/plastic bumpers on the sides of the fenders need to be adjusted. i would also clean and re-lube your latch to make sure it's got smooth operation.
Old Sep 4, 2014 | 08:43 PM
scope103's Avatar
Originally Posted by Sturmcrow
... If you look at the corners of the open hood you wiill see some plastic screw things. Screw those in or out until your hood works properly.
That's the purpose of those "plastic screw things" in the corners (not of the hood, but below the hood where it just about touches the front rail). If they are screwed IN too far, even though the hood is properly latched, it flaps up and down. Carefully screw those posts out until you've just taken up the slack.
My guess is that you will find those posts have just gone bye-bye, and that's your problem.
Old Sep 5, 2014 | 05:42 AM
nothingbetter's Avatar
having adjusted hundreds of hoods, those rubber screw things are so you can adjust your alignment height with the fenders. Don't use them to adjust the tension on the hood. You need to move the latch to do that.
Take off the latch and move it out of the way. Close your hood. check for proper alignment with the fenders (using the rubber screw things and the bolts near the firewall) Once the hood is aligned well, THEN you can install the latch and adjust it up and down for proper tension. Enough to just latch is all you need. if you have to slam it, its too much and you can damage your hood.
Old Sep 5, 2014 | 11:36 AM
Jake28296's Avatar
Thanks ill try it out!
Old Sep 5, 2014 | 12:34 PM
Sturmcrow's Avatar
Thanks for that info, nb. I was putting the cart before the horse.
Old Sep 5, 2014 | 12:52 PM
Jake28296's Avatar
Thanks it worked great doesnt even budge now
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
Davebarbier
Nov 3, 2015 03:28 PM
tysen86
Sep 25, 2015 11:15 PM
