runs off ether
Old Aug 11, 2014 | 08:37 PM
88beater's Avatar
runs off ether
Ok I have an 88 pickup just put a 93 22re in it to replace the blown up one it has spark and fuel and is in time but will not run unless I spray ether in it runs like a raped ape on ether but dies as soon as I stop spraying any help is greatly appreciated thanks in advance
Old Aug 11, 2014 | 09:37 PM
Chilton's Avatar
When I was in the Army we used to use ether for cold starts on our Semis and maybe even our old 5 tons. The old timers said that once the engines got some they quickly became dependent on it.
Old Aug 12, 2014 | 03:35 AM
85sr5excab's Avatar
Do u have ur afm hooked up to the throttle body and plugged in? Won't run without it. I've made that mistake more than once.
Old Aug 12, 2014 | 05:43 AM
Terrys87's Avatar
Are your injectors firing? https://www.yotatech.com/forums/f116...t-22re-270857/
Old Aug 12, 2014 | 07:32 AM
88beater's Avatar
No idea what an afm is I primarily deal with diesel engines and Chevy small blocjs
Old Aug 12, 2014 | 07:39 AM
RJR's Avatar
RJR
The AFM is the air flow meter. It's the big box right at the driver side front of the engine compartment just after the air cleaner. A large air intake tube goes from it to the throttle body.
If you're spraying ether into the throttle body, you likely have that intake tube disconnected. In that case, there's no air flowing through the AFM. Without air flow, the fuel pump is cut off. This is a safety feature to prevent fire in the case of an accident that stops the engine with the ignition still on.
Connect up your complete air intake system and try again. It'll probably run just fine.
Old Aug 12, 2014 | 07:46 AM
88beater's Avatar
I'll try when I get home thank you very much
Old Aug 12, 2014 | 06:37 PM
88beater's Avatar
Got home and she fired right up thank you very much
Old Aug 12, 2014 | 08:20 PM
RJR's Avatar
RJR
Great! Thanks for the update.
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
