'93 AFM internals not working in new AFM
Old Aug 31, 2014 | 09:17 AM
PapaChulos4U's Avatar
So, I went to ye olde Pick 'n Save the other day and thought I had struck gold: I found a functioning 22RE AFM out of a fellow '93 like mine, but I also found a functioning AFM out of an '87 Cressida with a 5MGE (this is the only 'ssida I've ever seen in the place, by the way).
I came home, threw the 'ssida AFM on and the truck started, then the CEL came on and the truck wouldn't rev past 3K, though it did seem throatier up to the 3K. So, I decided to take the internals out of the RE AFM and throw them in the other one, and wouldn't you know it, I found this:
...the RE internals don't fit. The board is too narrow and the screw holes need to be widened to attach it.
Anyone else had this problem? What can I do?
Old Aug 31, 2014 | 09:21 AM
Terrys87's Avatar
The only AFM I am aware of being interchangeable is the 82 Supra and it has the larger bore. You will probably have to get one off of a 22re as far as I know. Is there something about a Cressida that interchanges that you havent mentioned?
Old Aug 31, 2014 | 09:33 AM
I knew going in that it wasn't a direct plug-and-play, that's why I got the spare 22RE AFM so I could move the internals over. Others have written on here that it's possible. Check out this link:
https://www.yotatech.com/forums/f128...d-swap-248705/
This is precisely what I did, but the RE board isn't big enough. I don't understand.
Old Sep 1, 2014 | 05:01 PM
BUMP
Anyone? I know I can't be alone on this...
Old Sep 1, 2014 | 07:51 PM
Hugh_Mann's Avatar
Did you pull the entire AFM from the wrecked 22RE or just the internals? Couldn't you just have swapped the entire thing over?
Edit: I think I misunderstood. You're trying to move the internals from the wrecked 22RE AFM into the Cressida AFM?
Old Sep 2, 2014 | 01:10 AM
Terrys87's Avatar
Thanks for the link. To bad he didn't mention the exact year of AFM he used. Toyota likes to always change something and I wonder if that is the issue you are running into.
Old Sep 2, 2014 | 06:44 AM
Yes, The AFM did not work when plugged straight in: it threw the CEL and the truck wouldn't rev past 3000 RPM. Thusly I decided to transplant the internals from the RE to the 'ssida AFM but it's about 1/4" too short to be correctly installed into the Cressida box.
Old Sep 2, 2014 | 06:48 AM
I'm thinking that's what it is. I know the big blue oval is notorious for changing modules and parts mid-model year (some of them seem to change from day-to-day honestly), maybe Toyota is doing the same thing. These early EFI systems are pretty bad and they were always tinkering with things to improve them. At least it only cost me $30 total
ashersullivan88yota
Jan 18, 2022 05:37 PM
crashburnoveride
Aug 28, 2015 09:20 PM
Johntom240
7
Jul 13, 2015 12:18 AM
A2theK
Jul 12, 2015 10:46 AM
madxman21
Jul 9, 2015 10:26 AM
