- code 12- O2 sensor
- Need Help Identify Sensor
- 87 4runner trouble
- timing tensioner bolt
- Project Update: almost there!
- Rear window/door trouble
- Thorley header install
- Does the TPS require periodic adjustment?
- my new exhaust :)
- difference in 88 to 93 3vz?
- Non tubular bumper info
- 1986 4runner starter wiring
- Engine compatibility
- Quick question about ISR mod?
- 3vze auto to 5 speed swap.. need info on what i need
- sumthin strange is-a goin on...
- removing front bumper
- From bad to worse...
- So I tried to have an alignment on my truck done...
- Bad t-case bearing on the rear out put shaft on in side the t-case
- locking hubs question
- 1990 4runner build part 2
- Tailgate shackles
- ? about swaping parts with toyota van
- Swapping in new torsion bars
- Gas gauge out
- 1st gen 4runner and 84-88 pickup doors interchangeable?
- Swapping side mirrors???
- Fixing Seat slider things
- 95 3vze auto to 5 speed swap help
- Recomend me 4x4 stores in LA, please...
- Little Black Box
- Are high flow cats smog legal in CA?
- Finicky oil light..
- 1st Gen motor question
- brake master cylinder float issue?
- clickin noise
- Strange Whooshing/Roaring Noise
- Engine mounts!!!!
- plug-wire day...
- No Start, No Codes! I need help, PLEASE!
- Need some input Please????
- How to remove?
- Help Needed to pass smog!!!!!!!!!!!
- where do these go?????
- brake/fuel lines, AGAIN
- Not starting...help?
- Fast clicking noises when trying to start
- WHAT THE ????? coolant burning on #1
- what the hell?
- 32" s on stock 90 stock 4runner
- Hesitation during acceleration
- Arizona Emissions Passing Help
- any body have a bobbed 2nd gen?
- I need HELP BAD!
- Towing
- What do you do when your winch rips your bumper off half way?
- First time to Reiders and off course i broke something
- Throwout bearing? You tell me...
- SAS question..
- My 91 Toyota
- 4runner Rear Window Not working?
- Cam/ignition timing problems 22re "long"
- 3VZE knock sensor WIRE
- WTH? Did I jump 12 teeth on my chain?
- CV Joint
- starter shorting out cleaning contacts
- Third Member Swap Questions
- 3RD member Questions
- 4in bracket lift and 3.5in rancho working together?
- How much would you ask???
- condensor
- Pirate McGee's Pics
- 90 4 Runner 3.0 Oil Pan Leak
- how to remove PS fluid from concrete?
- rebuilt engine swap
- 1986 22RE Timing Help
- A question about my 4runner
- [OPINIONS]: Buy or Build? Engine swap options?
- getting heads machined, what else need to be done?
- 96 Taco wheels fit on a 92 Runner?
- 3VZE head gasket or Engine block swap
- Need Help!
- bit of an issue with my brakes..
- need help with clunk!
- head replacement advice
- Weighing my runner options. Newbie Help
- Low RPM on hot weather
- 1st,2nd,3rd,4th,5th where'd you go?
- idle problem... too high
- ISR/Snorkel Instal
- 89 4Runner
- 89 4 Runner
- Is this right? Another rotor question
- Hg?
- Idling Stalling And Misfiring
- What do you think?
- Fuel problems
- Idle bounces with foot on brake?
- Ghetto lift?
- 22RE oil leak, need some help
- Need advice for my '89 pickup
- what can the stock tire carrier hold?
- coolest 2nd gen gauges ever?
- Whiny
- Hard pedal..little braking..
- frames
- Fpu
- Frame repair
- Moving to Incirlik Turkey, Recommended Maintenance prior to bringing the Surf with me
- 3.4 craigslist find
- *Stock clock question*
- upgraded cam?
- blown headgasket - parts advice
- i got a question about thermogasket
- Idle drop on initial start up
- POR15 and a NEW bed ..
- DIY Video: 93 Pickup 2WD front shock replacement
- Questions about BJ spacers
- May be purchasing 95 4Runner. Questions..
- 90 4x4 Parts Truck
- 22r intake with 4 barrel adapter on ebay
- No oil pressure
- My second gen with a flow master (vid)
- tailgate innards
- Engine rebuild
- manual stick shaking while over 50mph
- Nerf bars and fender flares for 1994 ext cab 4x4
- 22R Carb, fuel won't shut off
- Towed a jeep today
- Rear fender liner
- Dashboard bulbs
- Camo 4runners
- long day of front end noise..
- ~craigslist Find~
- Got my lift on (Like last month!)
- Need help gettin' started
- 86 p.s box for a 91 truck??
- Auxilary Starter Relay
- Check this out!!
- speed sensor help
- 3.0 Valve Cover/Valve Adjustment
- Running 35X12.50 on procomp lift kit
- Diff Bleeder woes and rear end q (long)
- new member w/92 2-door
- Stuck In 4Lo and some other questions
- Code 41
- EFI tank on 22r
- 2 problems-mysetery noise and electrical
- weak IFS power steering?
- Oil pressure and trannie temp sensors
- Clutch, Slave, or Master?
- lsd ifs front diff
- my new lift!! (rear shackle how to)
- How much our tranny's weigh?
- Is this bad???
- 4runner for sale
- Aftermarket Camshafts
- Need Help about my 4runner 1988. Plz
- Regeared with 5.29 and a tru trac
- idle surging after warm up
- Distributor Swap ?.
- ARB Airlocker
- Catalytic Converter Stolen Today
- did a compression test today and guess what....
- Dead Miss @ 3500 ???
- turned my 4wd into a 3wd today!
- 1996 4Runner 4WD SR5 fs- SoCal
- speedo bounce
- some pics of my 22re build
- Center Console getting pretty damn hot!!
- What is the best wheel base for rock crawling?
- POR-15 frame project documentation
- Parts online New and Used
- Snorkel after a 3.4 swap.
- YotaTech 2009 Calendar Submissions
- 22re intake duct
- Coolant Leak on '90 4Runner
- Help im ?????
- every journey begins with a single step..
- my new red snappah
- rear abs sensor
- Pics Pics And More Pics
- will not idle
- Jumping RPMS
- took swaybar off
- Sad Day, Sold The 4runner
- marlin crawler or regear?
- 1986 22ret turbo motor for sale
- long cranking on startup
- Fuel Pump... Electrical Problem
- ball joint info please
- RIDING With O/D off
- New Toy
- I want to say thanks..
- Need some advice
- 22R smog pump bracket
- ATF in the transfer case.?
- replacing driver door glass.
- custom 4runner "flares"
- Front end loose on 1990 Toyota 4Runner
- 3.0 vs 3.4 toyota engine
- Considering swapping my engine into broken 4x4
- reasonable shop cost for pinion seal replacment??
- need some help picking out 'new' 22re
- I am scaring away all the damn deer..
- air shocks
- 92 4 runner question on waterpump
- I cant seem to find the drain plugs for my coolant???
- Retrofitting AC PITA?
- 22RE Water Pump Studs: Torque or loc-tite?
- bolting on tow hooks in place of tie down points?
- Locker Testing Question
- '90 to '92 grill/headlight swap
- how does our ifs front ends engage and disengage???
- Need Help with trans
- I can have a free 4runner but it needs things, advice please.
- 265/70r16 on stock height stock geared 22re
- No AC after HG fix?
- Anothe headgasket question
- Is my 4lo working?
- 93 vs 95 pu, any difference?
- Headlight Wire upgrade tutorial?
- So I need help on using my 4 wheel drive..dont laugh..
- Surging with the new AC Ide Up Valve...
- open diff. or not?
- Cruise control setup after conversion. HOW?
- Turning Point
- How to check waterpump?
- Hood Scoop 2nd 4Runner
- Cant get 4wheel light on dash to go out
- Installing new radiator, help please..
- $532 = 4"
- 95 truck bed won't separate from frame
- Power steering In and out
- $150 paint job
- How to I get this !@#$ rotor off?!!
- Leak in oil pan. Info needed
- Macgyver style trail repairs!
- share simple 22re mods? pictures of mine
- Questions & Suggestions Please
- Try again.
- Help choosing a suspension setup
- whats the difference?
- 92 Toyota Truck & 92 Mitsubishi Delica
- 4" Pro Comp Stage I Lift
- idler arm question
- body lift for an auto??
- Terrible Brakes
- body lift
