Is this right? Another rotor question
Old Sep 6, 2008 | 06:35 AM
rhale's Avatar
hello all, i have a quick question. on my 89 4runner (ifs) i have pulled the drivers side rotor to replace a broken wheel stud, but my question is in regards to the 54mm nuts. i have read on different threads that there is supposed to be 2 with a locking washer between. i have only one and it was loose when i finally got to it. do the ifs trucks only have one and the solid axle have two because of the cv axle's. last question is what should the nut be torqued to? thanks
Old Sep 6, 2008 | 06:49 AM
jason191918's Avatar
On my 92 I have 2 nuts and the washer. I use a hammer and screw driver for it. I snug the first and tighten the second. Haven't had any problems in 6 yrs that way.
Old Sep 6, 2008 | 12:33 PM
eric-the-red's Avatar
IFS should have 2 nuts and the locking washer, don't put it back with only one, it'll just come loose again.
Torque specs are in this article
http://www.off-road.com/trucks4x4/ar....jsp?id=186138
Old Sep 6, 2008 | 12:37 PM
904_runner's Avatar
i just had to do this too, yes, two are needed
Old Sep 6, 2008 | 03:37 PM
rhale's Avatar
904runner did yours always have manual hubs? i have auto hubs and upon looking at your pics and comparing it to mine, the one 54mm nut that i do have has 6 threaded holes in it that the hub bolts into with 3 torque head screws. i assume that will keep it from loosening.
does anyone know how tight it should be, or is it by "feel"?
Old Sep 6, 2008 | 07:02 PM
904_runner's Avatar
post a pic of yours!
no that pic i got off of 4x4wire. i converted my add flanges to manual hubs though!
heres the link
http://www.4x4wire.com/toyota/mainte..._end/teardown/
heres a link to the auto hubs version
http://www.4x4wire.com/toyota/tech/autohub/
good luck
Old Sep 6, 2008 | 10:33 PM
drew303's Avatar
is this what yours looks like?
I didnt know the ADD hubs were that much different from the manuals... Manuals have two nuts and a starwasher.
88sasturbotoy
Jan 30, 2026 01:57 PM
garagespace
Oct 11, 2015 10:59 AM
makemusic116
Aug 2, 2015 04:40 AM
ahriman
Aug 1, 2015 10:38 AM
msane99
Jul 11, 2015 08:08 PM
