Arizona Emissions Passing Help
Old 09-08-2008, 09:25 AM
VedraMax's Avatar
I have a '87 4x4 22R Pickup.
I am trying to register it in Arizona, but I didn't fully pass Emissions.
The Carbon Monoxide was too high and I am having trouble finding a shop that can "fix" it to pass.
Any suggestions?
Old 09-08-2008, 09:28 AM
abecedarian's Avatar
this is probably a dumb question, but do you have a catalytic converter on the truck?
any signs of exhaust leaks?
Old 09-08-2008, 09:31 AM
algranger's Avatar
i would run sea foam through it that helps a lot but it fowls your plugs so youll wanna put new plugs in whenthe seafoam is out of the system. also try replacing the air filter, and maybe the catalytic converter if thats bad its almost surely whats giving you trouble. and take it for a 20 min drive at high r's like 3k or something to heat up the catalytic and clear out the system a bit before your test
Old 09-08-2008, 09:33 AM
Here's another thing to help:
http://www.recarbco.com/technical/smog/smoginfo.html
Old 09-08-2008, 12:02 PM
VedraMax's Avatar
I really am not sure if it has a catalytic converter or not (had truck for less then a year). Every shop I've gone to makes suggestions, but don't have equipment for older Trucks. The neighborhood shops seem to think it's my carburetor.
Old 09-08-2008, 12:44 PM
it could be the carburetor.
if you have a catalytic converter, it would be under the cab, almost directly under the driver's seat. it would look like a short muffler (almost). the pipe would come down from the engine and turn to go under the cab, and the converter would be about 12" back from where the pipe goes horizontal.
If you don't have one, that could be part of the problem. If you do, then maybe the fuel mixture is rich. That's why I posted the link to a troubleshooting chart for smog problems with carbs.
Old 09-08-2008, 03:52 PM
Myron's Avatar
With my mr2...i went to checkers and got something that is called..Guaranteed to pass emission. You pour it into your tank..fill up..drive around for half tank..and then take your ride in to get it emissions.
if it doest pass..they give your money back. My mr2 failed like5 times..
after this...I PASSED...
try it out
kawazx636
10-06-2021 03:03 PM
dbollier123
09-29-2015 05:23 PM
Keithstoyota
09-27-2015 07:29 AM
taraf
09-25-2015 02:57 PM
Quick Reply: Arizona Emissions Passing Help
