$150 paint job
Old Aug 29, 2008 | 06:18 PM
toy89yota's Avatar
$150 paint job
So I have decide to paint my truck.
I am using epifanes monoureathane in dark green, i was going to use interlux brightside like some folks have but it didn't come in a color i liked.
I figured i would take it step by step on here as best I can so everyone can see the progress. I have never painted a vehicle before so bear with me on this one. Any tips would be greatly appreciated.
The paint I ordered from Jamestown Distributors, I got a DA sander at walmart to sand her down and the rest of the supplies I purchased at the local hedals auto body store.
I have access to a paint booth at work so I hope to do as much of it there over the long weekend as I can.
Heres a few before shots. Wish me luck.
Old Aug 29, 2008 | 06:24 PM
Gizler00's Avatar
I think the truck looks nice. Why paint it??
Old Aug 29, 2008 | 06:27 PM
toy89yota's Avatar
Its starting to get surface rust spots and it lost paint in a few spots due to cracking. I want to fix the dents too.
Look at the second to last picture above right behind the rear tire, my exhaust pipe fell off duck hunting last year, and after a whole day driving to decoying spots with the hot exhaust hitting the inside of the bed the paint fell of leaving the factory primer behind.
Old Aug 29, 2008 | 06:47 PM
space-junk's Avatar
still... kinda like that root-beer brown color... too bad its gonna go...
Old Aug 29, 2008 | 07:06 PM
jsn_stockard's Avatar
My first tip is stick with that color, I have never seen it on a Yota and I dig it. If you do much wheeling i would advise a single stage paint, cheaper and easier to spray. The paint job is only as good as the prep job, so spend the time. Use a big compressor, a 220 v is better than the 110 v because of the cfm to paint. An inline dryer is a must, and have fun doing it, cause thats what its all about!
JamesD's Avatar
Brown is a cool color. You do not see many vehicles that are brown. My vote is for brown.
James
Old Aug 29, 2008 | 07:30 PM
toyotatom93's Avatar
ya I also like the brown
Old Aug 29, 2008 | 08:00 PM
Djlarroc's Avatar
Just re-paint it brown.
Naw jk, your truck body looks good. Should look nice when you're down. Good luck!
Old Aug 29, 2008 | 08:58 PM
toy89yota's Avatar
some day maybe in like 5 years ill repaint it original paint code but for now i just need it done. if i dont like the green oh well repaint i guess. i have only seen one other toy with paint like mine a 93 4runner but in mint condition.
Old Aug 29, 2008 | 10:49 PM
toy89yota's Avatar
heres some pics before sanding, just got done stripping her down. Tomorrow Im gonna start sanding and bondoing the few small dents I have.
Found something interesting on the passenger side mirror, there were no nut plates holding it on like the driver side. It was held on with wood screws that had rusted, something else to fix I guess. I don't know if this truck came from the factory with out a passenger mirror and someone just screwed on on or what, any of you guys ever run into anything like this?
stripped and ready for sanding. Any last advice before i really tear into this thing?
Old Aug 30, 2008 | 12:52 AM
gte718p's Avatar
I would also take the antenna base, the rear bumper, rear turn signals (can't see if they are done), mud flaps and the CB antenna base off.
Sand outside, spray inside. Most people just hand up plastic sheets. I personally like to build a paint booth with PVC, plastic sheet, duct tape and bunch of cheap air filters. I think supplies cost me 200 at home depot, but I've used it a couple of times. It does a great job keeping dust and crap out of the paint. It also allows me to vent fumes well away from the house.
Finally make sure you have a really good respirator. Aerosol paint is really bad for the lungs. If you can smell paint either your filter is wrong, or the respirator does not fit. Get a good one your health is not something to go cheap on.
Old Aug 30, 2008 | 08:40 PM
toy89yota's Avatar
I have access to a paint booth at work where I'm gonna spray maybe. I'm also gonna sand there too, they issued me a respirator so I dont kill my self by breathing chemicals.
Old Aug 30, 2008 | 09:02 PM
toy89yota's Avatar
well my paint that I order will not be here till Thursday now. I have been tossing around the idea of spraying bedliner between the bed and cab because I drive alot of gravel while hunting and i noticed that that area was starting to get chipped up. So tonight I just got done putting the bed back on and i will start sanding the body tomorrow.
Pulled the bed off with the hoist at work.
sanded and taped before spraying
I used cheap dupli-color from walmart
turned out ok I guess.
Old Aug 31, 2008 | 12:34 AM
gte718p's Avatar
It is always nice to have a paint booth laying around. I have not been real happy with how the dupi color stuff held up. I would go with a Herculiner or something like that. Also turns out to be really good in the bed. Surprise. Its held up to a ton of abuse in the back of my 4runner.
Looks like your off to a good start, have fun and keep up the pictures.
Old Aug 31, 2008 | 08:58 AM
Moonfish's Avatar
If I ever got the bed off, I'd touch up the inside of the fenders and the frame. Also oil up that spare tire holder/torture mechanism.
Old Aug 31, 2008 | 12:00 PM
toy89yota's Avatar
I sprayed the cab floor with dupli-color last spring and it has really seemed to hold up nicely, but there i prepped the out of it and sprayed it on with a body shutz gun. turned out really nice and keeps the noise down on the highway. I wanted to do durabak but that stuff is $120 a gallon
Old Aug 31, 2008 | 12:06 PM
toy89yota's Avatar
Taking the bed off was a lot easier that i thought it would be. all 8 bolts holding the bed on loosened easily. the hardest part was probably trying to get all the wire clips off the bottom of the bed without breaking them, it only took about 4 hours for me to get the bed off, spray the cab and bed, then put it back together. It would have been nice to have two people but hey its labor day weekend who wants to work on someone else's truck right.
Old Aug 31, 2008 | 11:08 PM
toy89yota's Avatar
I had a few hours free this evening so i started sanding my truck. I used a DA sander with 320 grit and a flexible sanding block with 320 grit as well. I have never done any body work like this before so if im messing up someone please tell me. I had a big crack in the paint which I sanded down a was and i dont know if thats bondo or what but it looked different then the rest of the spots i sanded. I got it about 1/3 sanded.
Old Sep 1, 2008 | 07:13 AM
Gizler00's Avatar
WOW . You got a TON of work done since the other day. It looks good so far. I really want to take the bed off of my new truck and take care of all the problematic areas before they become a problem. I have done bodywork before but never painting. I can't wait to see how it turns out for you. Good luck and keep posting your progress. If there is anything I can help you with let me know. I have a whole 90 pickup sitting with alot of good parts still left on it.
Old Sep 1, 2008 | 12:13 PM
toy89yota's Avatar
yeah i do need some parts mainly interior parts for a brown interior. I just havent seen many like mine with the brown interior. Two 4runners thats it i think never a pickup.
