Considering swapping my engine into broken 4x4
Old Aug 31, 2008 | 02:07 PM
Duartizzle's Avatar
I have a 2wd 93 4Runner v6, i found a 4x4 4runner v6 that needs a new engine. How hard is it to swap the engine over? I would just need to swap the engine, ecu, and wiring harness right?
Old Aug 31, 2008 | 03:26 PM
abecedarian's Avatar
if your only going to swap the block and heads, nothing else should be required.
There may be some variables if you're going to be bringing the manifolds and stuff over to the new truck though.
Old Sep 1, 2008 | 10:41 AM
Duartizzle's Avatar
My plan is just the motor itself, would i have a problem with the ecu since it wont be for a 4x4?
Old Sep 1, 2008 | 10:45 AM
76ANTHONY's Avatar
no because your just using the engine not the trans and 4wd.
voiddweller
19
May 2, 2016 09:10 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
thelifeadventure
Jul 2, 2015 03:09 PM
TheManOutside
Jun 18, 2015 03:32 PM
