Installing new radiator, help please..
Old Aug 29, 2008 | 07:09 PM
digital's Avatar
Ordered the Heavy Duty radiator from radiatorbarn, can someone please tell me what is supposed to connect to the small outlets on either side of the radiator..My old radiator doesn't have these, thanks!
Old Aug 29, 2008 | 07:14 PM
digital's Avatar
haha, nevermind, should have read their web site first;
Q: I received the radiator and it looks like the wrong one – it has two extra ports” or holes in it that I don’t need – what do I do?
A: You received the correct radiator. These extra holes are for either the automatic transmission oil cooler or the engine oil cooler, and are there for your use only if you need them. It will not affect cooling performance, and you can simply ignore it. You don’t have to cap it off or anything – it acts as an independent unit and if nothing goes in, nothing will come out."
thook's Avatar
Those are for the automatic transmission lines, if you have an automatic. The auto tranny relies on ATF circulation through the radiator to help keep temps down.
Edit: Oh.....nevermind then!
Old Aug 29, 2008 | 07:27 PM
mt_goat's Avatar
I would run an ATF hose from one outlet to the other and hose clamp it in place. That way if the cooler inside the radiator ever ruptures you won't loose your coolant.
Like this:
And yes they do sometimes rupture, I can post up 4 or 5 threads of guys on here that had them fail.
Old Aug 29, 2008 | 07:32 PM
slacker's Avatar
or at least "block them off"
Old Aug 29, 2008 | 08:28 PM
thook's Avatar
Oooo....guess I'll be doing that real soon, then. Thanks for the tip fellas.
Road Bull
Oct 10, 2015 04:55 PM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
jjrbus
Jul 19, 2015 02:06 PM
horunner1x
Jul 10, 2015 06:33 AM
