- Front Diff question
- rebuilt motor wont start
- Spare tire bracket - 95 4Runner
- Camper Advise
- Transmission problems? Rattling/ Vibrating at 35mph
- which rims?
- truck running better w/out 02 sensor?
- How to remove 4Runner side mirrors?
- loctite during engine assembly
- F/S: 1990 4Runner Factory Repair Manuals
- Mods for a 1995 4Runner SR5 3.0L V6
- Well, air-con works
- removing intake manifold
- Yet another stuck fuel gauge...
- Intake Mods and pinging
- can't seperate rotor from hub
- What causes the "brake" light to stay on?
- value of good heads on a 94 3vze 3.0
- 93 pick up coolant problems
- HUB's
- a bit more power(22RE)
- gutless 22re?
- Spray in linered' rear bumper
- New style "Halo Reverse glow gauges".
- spare tire removal without tool kit...
- 3vze cooling sensor problems
- 4x4 engages but no 4x4
- Icehawk 87 4runner
- overheating/head gasket question
- new tires for the 4runner
- Finally pulled my 22r (pics)
- caliper advice needed
- 22-re mystery vibration
- engine survey...
- yota junkyards in western MASS??
- is there a "plug and play" AFM out there????
- 22R-E Problems
- 4" IFS lift
- 3.4 swap q?
- Loud exhaust on cold start...
- 3.0 injector style?
- check engine light?
- New (to me) 1990 4RUnner 3.0 v-6 questions....
- The Best & *Only* Intake That Actually Works! $25-40usd
- Depressed engine rebuild moment of glory failure blues
- Caster off,bent A arm.
- Finally, repaired my truck
- Timing not advancing
- Idle stumbles sometimes when warmed up.
- Fender flare protective strip???
- rattle noise in 1995 engine
- Immediate response needed for heater
- 1987 4-runner rear door needed
- Centerforce II or dual friction?
- troubleshooting rear differential and axles...
- Lifting My truck
- My rear coils are too soft - what to do?
- Proper torque for Wheel bearings
- My 3.0 just had a spark plug fly out
- my attempt to disable drl's on 2nd gen 4runner..
- head gasket repair
- Climate Control lights ?
- Ball Joint Replacement Help
- Downey Spring kit brake line problem
- wideners vs. deep dish wheels
- IAT sensor
- idle adjustment, afm adjustment, & timing questions
- Right or left head
- have some ign. timing issues. . . .
- 4runner Exhaust
- Hoods
- The 7.5" Supra LSD into a IFS diff thread.
- sas
- swapping out fuse box
- 1st gen rear window problems
- 22RE engine serial numbers?
- B-pillar exterior plastic trim removal?
- What's the difference in 2wd and 4wd radiators?
- 02 sensor install.... stripped nut
- need direction concerning front axle bind..
- Rear Hitch
- Is this any of you?
- Towing a trailer...anyone run 75w-140 in the rear?
- Temp Sensor and Temp in Cluster bad?
- Opinions... Black wheels?? Possible Photoshop needed
- need door chime module
- Do the 88-89 3.0's have headgasket problems?
- 22ret transmission swap
- temp guage hardly moves?
- Need some help today, sensor issue, please!
- help me wrench day.
- pacesetter headers
- Weird 3.0 noises
- Cheap muffler
- 8000km towing 2000lbs - 4runner rear coil/shock question
- Check Engine Light 22RE
- 4.10's and 33's
- injector question
- replacing battery cables
- straight six swap?? pros//cons?
- NEW 22RE oil pump priming
- modules underneath drivers kick
- 22re idle smoothness survey
- Exhaust wraps...???
- Anyone use Jeep YJ leafs for rear swap?
- Help Tire Problems
- Replacing TPS didn't work, now what?
- Is there a tranny fix/replace option?
- 3.0 no power, rough idle, wont rev over 2500
- 87 4runner starting problems
- ? found during head gasket replacement
- Cap with a burnt high tension cord plug
- what year of beds will fit?
- Idle surging...please help
- Help w/Wiring -remote starter and MSD 6A (Pics)
- Front right wheel howling noise in 2wd w/ locked hub
- transmission ?
- strange smoke!!!
- Cluster upgrade question(s)
- anyone know about clutch master clutches??
- OME #s for Pickups
- 2nd Gen 4runner front bumper options
- hmm.. caped off vac line??? Not in my truck!!!!
- VAFM and Timing
- Anybody have a closeup pic of the altimeter.......
- Rear leaf springs the same on 84-89 4runners?
- Simple timing chain question
- questions about my door jam code
- Help!! Balljoint spacer install gone wrong!
- Re-gearing...
- The 22re bleeds black today.
- 90 4Runner Oil Pressure
- What does the DECK LAMP switch do?
- 22re engine install
- t-case rear bearing
- 2nd gen n00b question
- doin brakes tomorrow
- cheapest place to buy 2nd gen chrome brushguard or bull/lightbar?
- '93 pick-up 22RE running hot, rough idle
- Oil change creating high idle
- '88 Power Steering Fluid
- Pic of my rig w/ snorkel
- 4R Noob seeks advice on typically problematic years
- Not wanting to satart on cold days
- Starts then dies then wont start...?
- Rattle from the engine
- Flooded my motor
- 22re driving me crazy!
- New valves, upgrade cam?
- erratic idle & hesitation in '95 4runner 22re
- Rear Washer Pump Just Stopped Working
- Heater only works when accelerating?..
- slider installation
- recommended over the k&n fipk intake??
- Loose/unknown wire underneath dash???
- 22re Ticking Noise
- truck got partially submerged
- lift
- Dilemma - Sell the '94 and buy a '99?
- New Runner Mods?
- Cable Driven vs. Electronic Speedo/Cluster
- Camper Shell ?
- finally installing a tranny cooler this weekend
- Good mechanics in the New York City area?
- Hub Install Problem Help Fast Please!!!
- my 94 runner what do u think??!!!
- Synthetic oil significantly reduced valve ticking in my engine
- 4 low not working???
- weak clucht pedal
- need power/gearing advice please!
- No diagnostics port....
- Anyone else have this one on theirs?
- driveline brake
- Is My Master Cylinder Dead.
- 4wd Help
- Inclinometer installed on dash, in factory pod. Pics!
- test pipe?
- anyone notice a power gain with a header?
- aftermarket tach or oem cluster?
- First tech - vacuum leak?
- IFS Skid Plate Options
- Electronic Speedo Upgrade
- 22RE In 92 PICKUP??
- how to redo foglight wiring?
- Help identify please
- Check Engine Light!!!
- what cam is better
- about to pull the trigger on this used truck, but just noticed a problem [w/pics]
- Question on body lift?
- what to paint the frame/undercarriage with?
- tans stuck to block?
- Tacoma Leaf in Pickup Pack + Shackle
- A fix for the lean overheating issue!?!?!?!
- 22re when to shift?
- Stock winch on 3rd gen P/U 4x4?
- 2nd gen on 3rd gen wheels....
- Noob here looking for a 1st gen
- very little heat
- need help wiring a 3.4 swap in az
- help with 92 4runner v6 engine problems
- Gauges to install??
- More power for your 3.0 - new kits are in
- 93 4-runner/ check engine light/ 3.0 V6
- New tranny from Marlin Crawler
- trans and trans/case center of gravity
- Help with oil cooler removal
- 32x11.50 on Stock Rim?????
- 93 4runner...needs advice on engine replacement
- Gas Pedal
- Need Help - 4Runner Advice
- Driving me mad. Help with diagnosis.
- Rear leaf springs from JCWhitney?
- Thought you guys would like to know... I finished the H.I.D. retrofit into 2nd GEN!
- check engine light??
- Inclinometer Installed Pics...
- head lights go off while driving
- Which method of controlling my elocker?
- At a loss on pinging
- Oil question
- another gutter guard mod
- Starter/Ignition Problem 90 4Runner
- Anyone bought a 22RE from Sunwest Automotive
- first gen w/ hood scoop
- New wheels on! American Racing Mojave Teflon
- Interesting find: Timing advance (read)
- Getting rid of cracks in dashboard
- 94runner clutch problem!!!
- Thought I'd say Hello.
- Brake question
- got spark, got gas, still no explosion
- heater control valve
- Replace just timing belt or do the whole kit
- green 2nd gen with black wheels vs. silver wheels
- Can I disable/remove my rear ABS?
- all 3vze's are NOT created equally!!
- My Battle For More MPGs
- SR5 Bucket swap - well she's done
- post pictures of wheels
- More 3.0 POWER!!!!
- Side markers
- O-drive Prob
- Sway bar disconects
- how to determine if head gasket was replaced
- tube step question
- What Toyota TBs are larger then the 3.0 one?
- Who is from Manitoba here?
- door locks
- Rod-Knock? I've no clue what's going on...
- Tire size OEM or not
- Differential Interchange
