OME #s for Pickups
Old Feb 12, 2006 | 10:48 PM
91ToyTrck's Avatar
OME #s for Pickups
I have searched and searched for a post with numbers and what to buy from OME for an 89-94 toyota pickup. You can find about 25+ for the 4Runner, but not a single one for the different options for a truck. I would like someone to please post up the options and numbers for ordering OME parts for the pickup.
I'm sure I'm not the only one and wouldn't it be nice to have these numbers somewhere so people don't have to ask the questions. Thanks in Advanced.
Chris
Old Feb 13, 2006 | 10:27 AM
91ToyTrck's Avatar
Can someone help me and others with the same question please?
Old Feb 13, 2006 | 10:35 AM
jethro's Avatar
PM strap22.
To get you started...
http://www.trademotion.com/partlocat...&subcat1=82971
Old Feb 14, 2006 | 09:27 AM
91ToyTrck's Avatar
I have asked him a couple times and I don't wanna seem stupid and ask him again. Plus I see lots of write-ups about the 4Runners and I figured it would be good to have it already up on the site.
Old Feb 14, 2006 | 10:24 AM
callmej75's Avatar
Phil is lurking...he will post up on this thread...guaranteed! He never leaves any question unanswered when it comes to his products.
Old Feb 14, 2006 | 10:58 AM
Strap22's Avatar
Sponsoring Vendor
'86-'94 IFS Pickup Trucks
Front
OME N98 (Qty 2)
SDORI BJ Spacers (Pair)
Rear
OME N85 (Firm) (Qty 2)
OME N94(Medium) (Qty 2)
Rear Leaf Springs OME 18 (Medium) (Sold Individually) (Qty 2)
Rear Leaf Springs OME 181 (Heavy Load) (Sold Individually) (Qty 2)
Rear Leaf Spring Bushing Kit ) OME SB43 (Qty 2)
U-Bolts OME U53B (Qty 4)
Extra Leaf OME 18XL (Use for constant Heavy Loads)
Steering Stabilizer OME SD33 (Qty1)
The Rear Suspension has a few choices: For 1.75" use the Medium OME 18
For 2.25" use the Firm OME 181
To maintain either of the above at posted height under constant weight use OME 18XL
For the Front Suspension I would suggest a pair of SDORI BJ Spacers and Sonoran Steel Lower Control Arm Truss
I also would suggest Manual Hubs (less stress on CV's on the highway)
Copy and paste what you need and mail to info@trdparts4u.com for a Price Quote. Be sure to include your zip code. I hope this helps...........
Old Feb 14, 2006 | 11:00 AM
Strap22's Avatar
Sponsoring Vendor
LURKING..........Why yes I was and I did post up.
Old Feb 14, 2006 | 10:32 PM
91ToyTrck's Avatar
Thank you very much Phil. I was hoping you would chime in eventually. I do appriciate you those down in this thread. I'm sure that I wont be the only one to benefit from this post. This will make it easier to tell people when they ask about OME stuff for a pickup along with the 4Runner. Thanks again Phil.
Old Feb 16, 2006 | 08:25 AM
91ToyTrck's Avatar
Phil ~ Would that extra leaf be used as an AAL to go along with a shackle? I'm trying to find a way to give my leafs a little life again. They aren't sagging that much, but I don't want to throw a shackle on there and flatten the springs out more. I have seen a couple trucks running aal and shackle, but I don't know if there is a small aal that I could buy and still be able to use a shackle and only have around 2inches of lift.
Any thaughts ?
Old Feb 16, 2006 | 11:04 AM
Strap22's Avatar
Sponsoring Vendor
It would probably work but I do not have any referrence that says how much lift you would get. You would more than likely need new U-bolts but once again that depends on your old leaf pack. I did call ARB and they will not say for sure if it will work because it is designed to be used with their new Leaf Pack. So I would say this isn't the way to go for you. If anyone else has had any expereince with using these the way he wants to please chime in.
A2theK
Oct 14, 2015 07:10 AM
duckhead
Jul 17, 2015 04:45 AM
zytra
Jun 24, 2015 08:14 AM
BuzzardsGottaEat
119
Apr 11, 2015 08:00 PM
