Replacing TPS didn't work, now what?
Old Feb 14, 2006 | 08:36 AM
Bassinfool's Avatar
My truck had been idling around 2000 for the first 8 or 10 minutes it was running (only after the motor cooled down). I bought a used TPS from someone here that tested fine. Put it in last night, and it didn't fix the problem. Anyone have any ideas on what else to check? I'm lost. I know nothing about this kind of problem.
92 Pickup
V6 3VZE
Fuel Injected (Given, I know)
4WD
Old Feb 14, 2006 | 09:56 AM
hey man can you get ahold of a code tester odbII they run for about 120.00 it will reset and or troubleshoot your rig
Old Feb 14, 2006 | 10:08 AM
Bassinfool's Avatar
I could, but my truck is pre-OBDII.
Old Feb 14, 2006 | 10:21 AM
hondacrusher's Avatar
is it adjusted correctly?
Old Feb 14, 2006 | 11:02 AM
Toysrme's Avatar
Cool
If you truck is idling at 2000rpm it's only one of three things:
1) The throttle plate is not fully closing.
2) The ISC valve is faulty
3) (Very, very rare) But if you've played with your AFM idle-bypass... Un-play with it. If not, forget this & don't play with it.
Old Feb 14, 2006 | 11:08 AM
regularguy412's Avatar
LoL @ unplay with it
Old Feb 14, 2006 | 11:11 AM
snap-on's Avatar
well if its only doing it when cold its supposed to in order to warm up the engine quicker.
there is an idle up valve (ISC i THINK) that is responsable for doing this. (gets a signal from the puter that looks at the temp sensor)
Old Feb 14, 2006 | 12:02 PM
Bassinfool's Avatar
Yeah, I guess I need to check that. I swapped it out late last night & didn't check if it needed to be adjusted. Good call
I'll have to check that if the adjustment doesn't fix it.
I haven't played with it, but thanks for the advice.
I'll check back if those don't do the trick. Thanks, guys!!!
Old Feb 14, 2006 | 04:59 PM
AgRunner06's Avatar
Definitely adjust it. It will never run right without being adjusted.
I would also clean the throttle body if you haven't yet. I'd also spray some TB cleaner into the valve cover breather hose while it's running. Maybe it will go through the TB and open up anything that is stuck. Maybe even try some SeaFoam. Lots of people like it.
Check for vacuum leaks. I found some on the two hoses that go to the PS pump. They are very hard to see.
Check your throttle cable. I had a high idle issue when hot that was related to the throttle cable being too tight.
Checking the coolant temp sensor can't hurt either but I'd do that once everything else seems to work fine.
Good Luck
:bounce2:
Old Feb 15, 2006 | 04:17 PM
suprathepeg's Avatar
Here is a good writeup on adjustment. You will need a multi meter.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Feb 15, 2006 | 05:33 PM
90!4Runner's Avatar
-Taken from www.chucknorrisfacts.com/index.html
I checked this out, and I can't believe I didn't have a heart attack. This is the funniest web site I've ever seen! One of my friends is obsessed with Chuck Norris, and he says some pretty funny things about him, and I'm definetly telling him about this site.
Sorry about posting this in here, but I feel it needed to be said.
Old Feb 16, 2006 | 01:45 PM
Bassinfool's Avatar
Yeah, I was dying. I got that address from another post on here.
zd92655
Mar 6, 2022 12:58 PM
bigblue82
10
Jul 6, 2015 08:27 AM
gog1968
Jun 22, 2015 05:55 AM
infinityisfive
Jun 16, 2015 06:51 PM
