trans and trans/case center of gravity
Old Feb 7, 2006 | 01:46 PM
kccorvette's Avatar
hey guys im just about to drop the trans and case to put in a new clutch and was wondering where the best spot to place the jack (on the tranny/case) to avoid tipping. This is my first time ever dropping a tranny and replacing a clutch. any advice is weclome. all i have left to do is unbolt the crossmember from the frame and the bellhousing from the block.
thanks
95 4runner SR5
Old Feb 7, 2006 | 02:12 PM
Elton's Avatar
i did mine with wood blocks and a creeper and a freind
Old Feb 7, 2006 | 03:02 PM
kccorvette's Avatar
how did you use blocks of wood?
Old Feb 7, 2006 | 03:06 PM
Flamedx4's Avatar
Unless you have a couple of strong friends, I recommend spending a few bucks and renting a transmission jack. Then the tip is leave the crossmember attached to the trans - makes it much more stable, and strap the whole thing to the jack.
Old Feb 7, 2006 | 03:12 PM
kccorvette's Avatar
but where should place the jack on the trans for it to be balanced
Old Feb 7, 2006 | 04:18 PM
Elton's Avatar
i would like to know how to get a trans jack under your truck when its on the ground
Old Feb 7, 2006 | 05:09 PM
kccorvette's Avatar
i dont have a trans jack i have large 3 1/2 ton jack which i used to raise the truck some then i placed a couple of jack stands under it. Now that the truck is raised I can use the 3 1/2 ton jack as a tans jack.
Old Feb 7, 2006 | 05:13 PM
kccorvette's Avatar
im going to drop the trans tomarrow but i would still like to know where i should place the jack on the trans for proper balance when lowering it to keep it from tipping
Old Feb 7, 2006 | 05:18 PM
Elton's Avatar
right in the middle strap it down real good and you should be fine
Old Feb 7, 2006 | 07:51 PM
kccorvette's Avatar
thanks
punks_is_4x4
May 31, 2016 06:03 AM
old87yota
Sep 9, 2015 12:39 PM
an1mal_69
Sep 8, 2015 09:40 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
justdifferentials
Sep 5, 2015 06:52 PM
