22re idle smoothness survey
Old Feb 14, 2006 | 11:03 AM
trythis's Avatar
When I got my 22re based truck, (89) I noticed the idle was horrible, absolutley teeth shattering. Intolerably so. If it was a stick shift, I know I would have had to hold it in gear. I did some work on it and it is pretty smooth, but I want to see how your 22re's idle.
How bad is/was your idle vibration?
What have you done to fix it?
I have theories about what could cause vibration:
fan out of balance
pulley not straight
tune up
motor mounts/tranny mounts
I replaced my EGR, pcv valve and grommet, plugs, wires, distributor cap, belts, hoses, and did the seafoam treatment, and timing. It shutters only a little while at a light, and oddly changes speed and vibration harmonics with the signals blinking, sometimes. I notice after a bit of driving that my brake foot left foot feels a bit tingly from sitting on the floor, so I would like it better.
How smooth can you get them? What shoudl I expect to acheive?
Old Feb 14, 2006 | 10:42 PM
Flamedx4's Avatar
Mine was smooth enough that if not for the a tach I wouldn't know it was running. It was still that way at 240k right after each tuneup.
Old Feb 15, 2006 | 04:15 AM
trythis's Avatar
Good to know, so I do have some more investigating to find out why it shudders at all.
Old Jun 19, 2006 | 09:43 PM
trythis's Avatar
An update, on a really exciting thread
I have solved 99% of my shuddering engine.
I replaced nearly all my vacuum hoses, and it is much, much smoother. I didnt test any of them, just swapped them out, and viola, smooth idle.
Old Jun 20, 2006 | 05:20 AM
05prerunner's Avatar
mine runs extremely smooth, even with the 02 sensor unhooked. the only thing you can hear is the exhaust leak that i cant seem to get rid of
montanatruck
Feb 26, 2017 07:07 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jake_v
Jul 22, 2015 03:17 PM
kcaudill
Jul 20, 2015 12:06 PM
kyletbert
Jul 17, 2015 11:39 AM
