caliper advice needed
Old Feb 19, 2006 | 12:48 PM
Brendan's Avatar
on both of my front calipers, the inside pad has worn down to zero percent while the outside pad has 60-70% left. i got a price from the local parts place and got a very good cost of $58 ea + core, but i would rather repair my calipers if possible. i was talking to a guy that knows much more about mechanics than I and he said it is very common for rusty pins to cause this problem and that if i just remove the surface rust on pins, i might be ok. just looking for some advice from someone else who has hopefully been there, done that. thanks.
Old Feb 19, 2006 | 03:21 PM
getitdone's Avatar
You can try to clean all the sliding surfaces from rust, but it sounds like a pretty drastic "stick". If you have 70% vs nothing I doubt that it's just a little rust on the pins, but it might be worth it to clean it up and see if it helps. I guess you will find out quick if it is rusted solid when you pull it all apart.
Good luck.
Old Feb 19, 2006 | 06:10 PM
Yoda's Avatar
Since the caliper mounts solid to the spindle, there are no pins to get rusty. There are 2 inside pistons and 2 outside pistons. The outside pistons must be binding to cause less wear on the pads.
Old Feb 20, 2006 | 12:11 PM
panhead's Avatar
calipers
try auto zone I just bought a pair of reman loaded with pads for $93
Old Feb 20, 2006 | 12:15 PM
bflooks's Avatar
panhead, $93 for two calipers? that is an awesome price!
Old Feb 20, 2006 | 01:03 PM
leebee's Avatar
im going to get me a shipping address in the states, it would be more than worth my while to buy stuff and have it shipped there, drive down and pick it up myself. i just paid 105$ for one loaded caliper. free trade, riiiight!
lee
Old Feb 20, 2006 | 01:12 PM
brandontrek's Avatar
prices are about the same through advanced auto...it depends on what manufacture you go with...
Old Feb 20, 2006 | 01:37 PM
w3s's Avatar
w3s
I had the same thing happen last year. Look at the price difference between a rebuild kit + down time rebuilding versus a rebuilt with warentee..
Old Feb 20, 2006 | 02:56 PM
fourwd1's Avatar
Yeah, you probably have some frozen pistons. You can try freeing them up before you buy new ones.
Old Feb 20, 2006 | 04:37 PM
funrunner91's Avatar
REBUILD......caliper seals and gromits 6 bucks each caliper (those pistons will free up nicely) and the pins are guide pins, they get a lot of rust and tend to bend after a few brake jobs....they are about 4 bucks per caliper (2 each)......so if you got 20 bucks and 2 hours do it
Old Feb 20, 2006 | 04:38 PM
PS....the guide pins are what the pad slides on, they get bent often and cause uneven ware
BigArt70
Jun 30, 2015 09:51 PM
Old Red 94
Jun 16, 2015 08:32 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
