head lights go off while driving
Old Feb 6, 2006 | 07:53 PM
sdstud212001's Avatar
Question head lights go off while driving
Okay I'm new here but I did a search first with nothing about my problem, so here goes. I just got my 87 4Runner and the other day I was driving (at night) and the lights cut out but the high beam indicator came on. I wasn't scared because I was on a surface road but I really don't want it to happen on the freeway. Oh not to mention the fact that people will think I am signaling them. It happened again the same night and I just pulled back to "flash" the high beams then let go and the regular lights came back on. Has anyone ever had this problem? Where should I start to fix this? Thanks in advance.
Old Feb 7, 2006 | 09:39 PM
Tiger Paw's Avatar
I've had the same thing happen to me before when I'm switching from low to high beams. Pretty scary when you're expecting them to get brighter and they just go dark. It doesn't happen every time, just occasionally. Maybe some one will chime in with a suggestion.
Old Feb 7, 2006 | 09:46 PM
Keggo's Avatar
Maybe change your bulbs. The bulbs' high beam filament may be out of whack... I don't think the high beam indicator would go on if the wiring was bad.
Old Feb 7, 2006 | 09:59 PM
Tiger Paw's Avatar
I have two new headlights so I don't think it's the filament. I'm starting to lean more toward the wiring or a relay as causing my problem. My high beam indicator doesn't come on, but I guess sdstud212001's does. Thanks for the suggestion, though. It might be sdstud212001's problem if his lights aren't new.
Old Feb 8, 2006 | 10:03 AM
Yeah my headlights are not new or anything, I have to agree with Tiger Paw I think it's electrical. Why else would the Hight Beam indicator come on when the Lows go off?
Old Feb 8, 2006 | 10:30 AM
Buck01's Avatar
Try this link and see if it helps you. Sounds like a similar problem to me.
http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Old Feb 8, 2006 | 10:47 AM
Thanks Buck01 I would have never found that. Yeah I think I will have to do that, I was hoping it wouldn't come to that but at least with that thread I might not have to buy a whole new lighting control. thanks again
Old Feb 8, 2006 | 11:41 AM
Buck01's Avatar
don't thank me..thank Roger..his is the guy that figures this stuff out...I just happened to read that and remember it...He has tons of great info on his site.
Good luck.
Old Feb 8, 2006 | 04:50 PM
brandontrek's Avatar
i have never talked to roger in person(only through yotatech) but he seems like a friggin wiz at these yotas...
Old Feb 9, 2006 | 07:04 PM
Tiger Paw's Avatar
Thanks for the link! I've been to Roger's site a million times, but I never noticed that section. I guess it was because I was never interested in upgrading my headlight wiring, etc. I should have known he had a cure for our problem. Roger for President!!!
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
