Proper torque for Wheel bearings
Old Feb 17, 2006 | 06:13 PM
I am a rookie in car repair. I need some infos How to repack front wheel bearings correctly without over torque and burn the bearings. I plan to take out the Brake disk for resurfacing and re install. I appreciate any write-up or inputs you might give me.
Thanks.
Old Feb 17, 2006 | 09:10 PM
YotaJunky's Avatar
I just did mine and used the following write-up:
http://www.off-road.com/toyota/wheel_bearing.html
Good Luck!
Troy
Old Feb 18, 2006 | 12:32 PM
Asha'man's Avatar
That's an awesome writeup! I need to do my pads and bearings soon too. Are there any parts that one needs besides bearings? I thought I remembered reading somewhere that the locking tab washer thing was a one-use deal. Oh, and is the spindle nut socket just a plain 54mm/2 1/8" socket, or is it special? I needed a four-pronged socket for the hub nuts on my old Ranger, for instance.
Brian
Brian
Old Feb 18, 2006 | 08:53 PM
YotaJunky's Avatar
Brian
Brian
Get locking tab washers just in case you break the ones you are removing. A regular 2-1/8" socket worked for me. Don't forget the bearing grease, mineral spirits or brake cleaner, and gaskets. You may need a brass bar to help loosen up the cone washers. Also, make sure you have a container for all your parts, otherwise you may lose parts. Lay everything out in the order of removal, so you don't have to guess what goes where. Taking pics may also save a lot of headaches later.
Good Luck!
Troy
Old Feb 18, 2006 | 10:39 PM
Keggo's Avatar
look in the yotatech tech section. there's also a write up on replacing the inner steering knuckle bushing with needle bearings... I sould suggest doing that at the same time.
glowz825
Jan 25, 2022 09:28 AM
jasonty
41
Dec 23, 2018 01:00 PM
sabine
Jul 18, 2015 03:59 PM
colasurdo
Jul 17, 2015 08:28 AM
Jnkml
Jul 6, 2015 01:20 PM
