Climate Control lights ?
Old Feb 17, 2006 | 01:59 PM
CANADA4RNR's Avatar
From: Beautiful British Columbia 1994 v6 3.0 4x4 auto
Lightbulb Climate Control lights ?
Was wondering if there are lights behind the climate control switches?? I think I used to have them but could be wrong? If there is are they on a seperate fuse from the gauges & or shifter lights. Also in the rear climate control behind the console? any help appreciated thx. 94 sr5 4x4
Old Feb 17, 2006 | 04:52 PM
Tiger Paw's Avatar
On my 89 I have one small bulb behind the climate control panel. Don't know about the fuse. Not sure if it proves them to be on the same fuse, but if the climate control dims when you dim the dash then maybe they are on the same fuse. Sorry I couldn't be of more help.
Old Feb 17, 2006 | 04:59 PM
Jeffires's Avatar
It's on the same fuse with the rest of the dash lights. There is a thread on here how to change it, but in short, pull the knobs off, pop the A/C button, and carefully remove the HVAC control faceplate. There is a small bulb that pulls straight out. It has a green rubber cover on it to make it appear greenish. If you are careful, you can switch this on to the new bulb.
Don't know about rear control, but you'd think it was on the circuit with the other dash lights...
Old Feb 17, 2006 | 05:59 PM
CANADA4RNR's Avatar
Ya i think I may have got some armorall in there or something because It stopped working after I detailed the interior...I'll have to look for that thread on replacing the bulb if It don't magically start to work by end of the week.
Old Feb 18, 2006 | 04:41 PM
CANADA4RNR's Avatar
Ok I got the face plate off and took that clear plastic thing that magnifies the light off too. Looking at the bulb with the green cover on it, are you able to pull this striaght out or turn it? I couldn't seem to get it out. Curious if I'd havr to go to the dealer to get that bulb aswell?
Old Feb 18, 2006 | 04:47 PM
Glenn's Avatar
It should pull straight out. I just replaced mine today. It does not twist out. I got two bulbs in a blister pack at the local parts house. They did not have the bulb condoms. They are Sylvania 74s.
Old Feb 18, 2006 | 04:54 PM
CANADA4RNR's Avatar
Awesome thx Glenn gonna go do that now. Cheers
Old Feb 19, 2006 | 02:42 PM
CANADA4RNR's Avatar
Done deal easy fix.....1.90 for 2
Charecter1
Nov 6, 2023 10:08 AM
AkitaDog
Sep 1, 2015 08:05 AM
kirkrunner
Jul 27, 2015 07:59 PM
rushw
Jul 18, 2015 01:46 PM
daddio
Jul 18, 2015 10:20 AM
