Timing not advancing
Old Feb 18, 2006 | 01:24 PM
John79's Avatar
I replaced the distributor on my 22re jumped the connectors and set the timing to 5 but when i pulled the jumper wire off the timing should advance but it stays on 5. Truck is extremely sluggish like this worked fine before. This just happened after I put in the new distributor. Can't figure out what may have gone wrong?
Old Feb 18, 2006 | 01:38 PM
Marc's Avatar
If it's like my 3VZE it could be the TPS is not adjusted properly.
I had a similar problem (mine wasn't retarding) and adjusting the TPS fixed that.
Old Feb 18, 2006 | 01:55 PM
phorunninduke's Avatar
That is pretty classic sign of having a bad TPS or it being out of adjustment.
Old Feb 18, 2006 | 05:57 PM
John79's Avatar
Yup that was it I replaced the tps awhile ago and the screws got loose and it was out adjustment I readjusted it and set the timing no problem.
jbv808
Aug 6, 2021 04:47 PM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
karbin
Jul 5, 2015 11:37 PM
