Tire size OEM or not
Old Feb 5, 2006 | 07:01 AM
Lanman's Avatar
My 1994 3vze has the Goodyear Wrangler RT/S 31x10.50R15LT tires.
Is this OEM?
I want to purchase new tires.
What is the original tire size for this truck? What is the tire size I should be using without making changes to the transmission?
Thanks for any assistance ...
Old Feb 5, 2006 | 07:15 AM
regularguy412's Avatar
Look on the plackard inside the lower part of the driver's side door jamb ( near the B pillar ). It should have tire size information listed there, as well as some codes that tell what the stock transmission is, as well as a code for determining differential gear ratios.
Mike in AR
If you have 31" tires on now and the stock size was P225, then your mileage traveled (odometer reading) and your speed are off by about 10%. You would be traveling 10% farther (and 10% faster ) on each tire revolution. So if your speedo shows 50 mph, you are actually traveling about 55 mph, 60 would be 66, etc. This correction will also help with fuel mileage calculation, too .
Last edited by regularguy412; Feb 5, 2006 at 07:20 AM. Reason: missed part of your question
Old Feb 5, 2006 | 09:16 AM
tc's Avatar
tc
31x10.50 was a factory option, but they were Bridgestone Desert Duelers.
Do a search for "diff codes" there is another site that tells you how to decipher the door jamb label for tire size and rear end ratio - that will lead you to what tire size options you have.
My '93 came with 31x10.50, manual transmission, 4.56 gears and I run 33x10.50 with no issues.
Old Feb 5, 2006 | 11:08 AM
MUDN4R's Avatar
When i got my 4Runner it came with 31x10.5x15s then i bought the same size Pro Comp Muds from a junkyard for $50 each <- Awesome Tires *not to good in sand but fun*
Old Feb 5, 2006 | 12:26 PM
trythis's Avatar
auto transmiaaions with 22re have 4.56 diffs and have 225 standards afaik. so there is some variation in what your supposed to have.
Old Feb 5, 2006 | 12:42 PM
kyle_22r's Avatar
nope, most had 4.30s, but some had 4.10s like manual trucks.
Old Feb 5, 2006 | 01:32 PM
Just to follow up -- Mine came with 225's and 4.56's - A340H auto tranny. I run 31 x 10.50's with no problems. Here's the link to the site with the key to the door jamb codes regarding gearing.
http://www.off-road.com/toyota/tech/other/4_axles.html
Mike in AR
Old Feb 5, 2006 | 01:37 PM
89macrunner's Avatar
my first gen came with 225's and i have 4.56 gears and a manual tranny...dunno how the heck it happend but it did.
im upgrading to 32's and im not afraid of any loss of power really
Old Feb 5, 2006 | 02:35 PM
kyle_22r's Avatar
typically:
base 5 speed = 4.10
base auto = 4.30
5 speed and 31" tire package = 4.56
V6, auto, and 31s = 4.88
Old Feb 8, 2006 | 12:42 PM
sandcrawler's Avatar
my 3.0 auto came stock with 225s and 4.56 gears, but when i bought it 31s and AR (or similar) rims were already on it. i'm now running 32s and don't notice any difference at all. actually, it's still pretty peppy -- if it's not hilly terrain, of course
can anybody point a bruthah in the right direction for calculating how off my odometer is? (btw: i've already checked out 4crawler's page)
Old Feb 8, 2006 | 12:58 PM
never mind my previous post; i just figured it out. p225/75s are about 28.5" -vs- my new 32x11.5s which are about 31.5".
using 4crawler's page -- http://www.4crawler.com/4x4/4LoCalc.shtml -- the one i couldn't find just a few moments ago i guess it comes out to be about a 10% delta/difference.
so maybe my mpgs aren't as bad as i thought they were...
Old Feb 8, 2006 | 05:09 PM
tc's Avatar
tc
Those calculators assume your speedo is right to start with.
In my case, this was not even close to a valid assumption.
GPS or stopwatch are the only ways to REALLY find out. Sorry
Old Feb 8, 2006 | 05:33 PM
4Crawler's Avatar
The tire size/inflation sticker on the door jamb will almost always list 225-75R15 even if the truck came with 31x10.50 or even 16" wheels.
Old Feb 9, 2006 | 06:12 AM
celica's Avatar
Yup, you can't go by the door jam for the wheel size. the gear ratio is a better indication. Mine was stock with 31" and it still says the smaller size on the jam
Old Feb 9, 2006 | 10:09 AM
good to know; i figured that if the rig came with the "big tire" package it would've been reflected in the door-jamb.
my spare was a p225/75, though, and the gear codes indicate 4.56, so it seems like that was the original setup. am i mistaken?
i'll give the GPS method a shot one of these days. it's not critical.
Old Feb 9, 2006 | 10:25 AM
celica's Avatar
Sounds like stock was the 225's on yours
Old Feb 9, 2006 | 11:05 AM
thanks!
Old Feb 9, 2006 | 11:15 AM
I believe mine came stock with 225s also. Looks like the original Bridgestone Desert Dueler was still under the rig when I changed to the 31's. But it kinda sux about the door jamb info. Now I'm curious about what gears I 'really' have. The door jamb info code says 4.56's. Gonna go jack it up and turn the wheel 2x ( open diff ).
Mike in AR
Old Feb 9, 2006 | 11:29 AM
if i'm not mistaken, the gear codes on the door-jamb are correct, even if the tire info is not...anyone care to confirm?
Old Feb 9, 2006 | 11:32 AM
4Crawler's Avatar
They are on the ID plate, under the hood in most cases, may appear other places as well:
- http://www.4crawler.com/4x4/ToyVIN.shtml
