new tires for the 4runner
Old Feb 19, 2006 | 01:33 PM
Kyle95sr5's Avatar
its about that time to put some new tires on my 4runner but i need help picking a size. I got a set of rims from my friend that have quite a good bit of backspacing so they do stick out alot. I am wondering whether i should go with 31x10.50s or 32x11.50s. i have 4.88 gears so either size would be fine power wise with me. i like the tires sticking out in an agrresive kinda way but i don't want them to look like one of those mexican cars. wut do u guyys think. any pictures??.
-Kyle
Old Feb 19, 2006 | 01:37 PM
Kyle95sr5's Avatar
if i choose not to use the new rims, could i fit 32x11.50s on my stock alloy rims and not have to worry about rubbing the a-arms or anything else?
Old Feb 19, 2006 | 03:09 PM
getitdone's Avatar
What kind of tire? If its a mud terrain you won't look too mexicany, but be careful if its an all terrain.
I like em wide. My 02.
Old Feb 19, 2006 | 03:23 PM
regularguy412's Avatar
You may have to customize ( read: flatten the inner fender seam at the firewall ) to avoid rub at full lock. A rim with a hub spacing that puts the center of the wheel farther from the A-arm will make any tire more likely to rub at the firewall and at the top of the fender on full compression.
Mike in AR
Old Feb 19, 2006 | 03:38 PM
rocket's Avatar
How much backspacing are you talking about? If there around 3.75" then your in good shape to run 32's and it wont look bad at all.
I'd do it. The most you might rub would be a tiny bit on the plastic valance when making a U-turn.
I ran 33x10.50s with no lift for a few weeks and had no issues worth mentioning.
Old Feb 19, 2006 | 04:34 PM
Kyle95sr5's Avatar
the tires that im getting are Dunlop Radial Mud Terrains..they look beefy and are really cheap. the rims that i would get, im not sure the backspacing but i know the do stick out quite a good bit on his nissan. rocket? do u got pictures of ur 4runner wit ur 33X10.50s with no lift?
Old Feb 19, 2006 | 04:44 PM
rocket's Avatar
Old Feb 19, 2006 | 04:51 PM
Kyle95sr5's Avatar
holy crap..u stuffed them up in there huh? wuts the backspacing on those rims?
by the way..i just looked over the thread of ur buildup..ur 4runner looks sweet...
Old Feb 19, 2006 | 05:15 PM
rocket's Avatar
They have 4" backspacing but i would of rather wanted 3.75". Shortly after i got the tires, i added a 1" BL and wheeled the crap out of it with no problems. I never got a chance to add my suspension lift but its a good thing i didn't...click the link in my signature to see why. I let my "buildup" thread die a long time ago cause i decided to slap all my junk on this summer.
The only rubbing i had with no lift was on the plastic bumper valance so i just took it off.
Old Feb 19, 2006 | 05:26 PM
tc's Avatar
tc
I have 33x10.50 on stock rims with no lift and no rubbing issues. I like the way they fill up the wheelwell. This is a fantastic tire size for Toyotas, unfortunately, the selection is pretty limited (BFG A/T and M/T, Dunlop Radial Rover RVXT, and SuperSwampers). I think the metric size is 265/85R16 and there are a few other choices.
Old Feb 19, 2006 | 05:49 PM
Kyle95sr5's Avatar
sorry for the repetition..tc, do you have a picture of ur truck that u can see the wheels good in?
Old Feb 19, 2006 | 05:56 PM
tc's Avatar
tc
Look around on here. http://www.4wheelingoh.shutterfly.com/action/
Here's a recent one:
BushPig
Oct 29, 2022 06:26 AM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
87blyota
Jul 8, 2015 09:16 AM
