22re Ticking Noise
Old Feb 9, 2006 | 09:35 PM
hockeybird's Avatar
22re Ticking Noise
Yes, I've done a search and it looks like this is a common problem with the 22re engines. I had a V6 in my old 4runner and had no problems, however, I just picked up an 88 pickup and its got a tick. The tick increases with RPM's and almost sound like a rod knock. Head Gasket has been done, timing chain has been done. Egine has 312,000kms on it. I want to know if this is something I should worry about?? If it is should I just drive it do the ground and do a swap when the 22re gives up or fix it or swap it now??
Old Feb 10, 2006 | 08:22 AM
s t A t i c's Avatar
My 92' runner was doing the same thing until one night it sounded like something blew up under my hood. I lost almost all power. the car moved at a slow crawl atmost. i got it back to the shop( i work at a chevy dealership) and it blew one of my spark plugs outta the block. I rethreaded and reaplaced the plug. Since then I have had no more leaking. The ticking for me was compression leaking out of one oe the cylinders. Can you feel air being pushed out of the block? if so i would have that checked out..
Old Feb 10, 2006 | 11:18 AM
hockeybird's Avatar
I'll check that out...thanks
Old Feb 10, 2006 | 11:44 AM
toyotaoffroad91's Avatar
its normal the valve train on a 22re are notoriosly noisey. Even if you get them to be quite you will still hear the injectors ticking away. perfectly normal
Old Feb 10, 2006 | 12:30 PM
hockeybird's Avatar
alright...cool..thats what I though after I read a few posts. Just kinda worried about this engine i guess cause I'll the KMS it has on it.
coleypull15
Nov 3, 2015 07:41 AM
PlayAwhile
Jul 20, 2015 11:36 AM
cars-guy
Jul 11, 2015 07:51 PM
smiley52
Jul 11, 2015 05:16 AM
Gamble_STi
Jul 7, 2015 07:54 PM
