a bit more power(22RE)
Old Feb 20, 2006 | 08:40 AM
JonathanG32's Avatar
can any one give me advise on how to make my 22re a bit more power full. i have pacetter headers,knn performance air filter. and now i just need to get my lc enginering cam in. i have 488 gears and runing 34 inch ltb swampers. i just need to get a little more power to go up some hills in colorado cause it struggles. any suggestions will help. o am almost thinking of turbo charging it. and now im getting a roll cage in it so that is going to make it alot heavier.
Old Feb 20, 2006 | 09:00 AM
Buck01's Avatar
without a turbo or super charger I think you have as much as you are going to get.
Old Feb 20, 2006 | 09:09 AM
Brendan's Avatar
what size exhaust are you running?
Old Feb 20, 2006 | 09:13 AM
inch and a half
Old Feb 20, 2006 | 09:45 AM
seaflea's Avatar
Go to 2.25" exhaust and ugrade the throttle body and plenum if it is the old style.
What year 22-re are you running?
Old Feb 20, 2006 | 03:30 PM
my truck is a 91 pick up DLX
Old Feb 20, 2006 | 03:43 PM
seaflea's Avatar
Then you already have the new style plenum and throttle body.
Old Feb 20, 2006 | 05:50 PM
89macrunner's Avatar
maybe upgrade your gears also.
Old Feb 20, 2006 | 06:26 PM
Brendan's Avatar
ya, 5.29s would give you some more low-end
Old Feb 20, 2006 | 08:05 PM
i just re geared it lasy may. and that was lot of money that took me a long time to save. but now i am thinkig of going to a 33 inch tire insted of a 34
Old Apr 8, 2006 | 07:55 AM
uhohhotdog151's Avatar
dual cases, throw that baby in low low and crawl, youll have more than enought power to turn those 34's
Old Apr 8, 2006 | 04:04 PM
kyle_22r's Avatar
the 34" ltbs are basically a 33" tall tire. they're one of the few swampers that runs small.
how many miles on your engine? the difference between a fresh rebuild and something with 200k on it is phenominal.
Old Apr 8, 2006 | 05:15 PM
AH64ID's Avatar
You have done just about all you can except forced induction. I would adivse you against getting overly optimistic about a cam. I put a TRD Stage II in my 95 22RE and all it really did was drop my fuel mileage, and gave me a lope at idle that sounded like a SB chev.
IMO, header and exhaust are best. 2.25" will help with low and high rpm. 2.5 is for high rpm only. Intake helps a little. Gears are huge, but you wont notice enough going from 4.88's to 5.29s to justify it.
Switching back to a radial tire would be the best thing you could do. I went from 33 TSL Bias to 35 BFG mud and it felt like I got 50hp...
Old Apr 8, 2006 | 08:03 PM
fierohink's Avatar
When I swapped in my engbldr cam it was like night and day. Hills I used to creep in 4th I pull strong in 5th. I am very happy with the cam.
Old Apr 9, 2006 | 11:35 AM
AH64ID's Avatar
Really, maybe a TRD Stage II is more than the ECU can handle, despite what toyota says.
What type of mileage do you get with that? How is the bottom end.
Old Apr 9, 2006 | 06:54 PM
fierohink's Avatar
I get 20-21 mpg and thats around town in the hills of MD and PA. When I go out to the shore I can baby it to around 25 mpg. And she's got pull all the way up the rev range. WAY more than stock.
I did a dyno run just prior to the cam swap. I need to get back to the shop to do a post run, then I'll be able to post numbers for improvement.
Old Apr 9, 2006 | 06:58 PM
AH64ID's Avatar
Very interested in seeing those curves and numbers...
Old Apr 9, 2006 | 09:08 PM
trythis's Avatar
fierohink, I am waiting with anxiousness....lets see the dyno
Sleaker
Aug 26, 2020 06:03 AM
mskalmus
May 28, 2017 07:51 AM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
Nickdigg
Jul 7, 2015 06:04 AM
