PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 [171] 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 87 1st Gen STEERING LINKAGE
  2. is this the only stock tire cover??
  3. scary thing happened to me, now questions
  4. Overheating 22re (I did search)
  5. Bazzare flooding problem
  6. check engine light
  7. Driver's door won't open!!
  8. anyone thought about putting in a 3sgte motor if possible?
  9. Still new to this,is this TB maxed out ?
  10. engine mounts
  11. Truck stopped running
  12. 7mgte tranny swap ???
  13. rinngin rich and pinging
  14. Pretty new here, posting pics
  15. Missing connections on back of 3VZE
  16. Need serious help with rear end
  17. 86 22re turbo wont start. Help!
  18. Custom dashes?
  19. Rear Diff and Driveshaft Advice? 88 4runner
  20. Lift kit recommendation?
  21. Runs rough and advice on gauges
  22. 87-89 4Runner Interior quarter trim restoration How To
  23. Tranny install HELP Asap!
  24. Truck after OME leaf spring install
  25. tranny questions
  26. Lift installed, WITH PICS
  27. Flat bed, or stock?
  28. parking brake parts diagram?
  29. 90 4runner tailgate disassembly question
  30. hood project...
  31. rust spots/ rust hole
  32. 92 4Runner Transmission
  33. The Herculining entire 4runner interior project thread..
  34. anyone have headers on a 2WD plz post
  35. Relay Box, Pushbar, Winch, and Lights Project w/Pics
  36. for questions on fan installs (for 22re)
  37. yota's and crashes
  38. New dent
  39. I saw a couple for sale...
  40. reed valve and cat theoretical question :p
  41. Lookie what I just got :)
  42. Help Troubleshooting after 3.0 rebuild
  43. New Tires & Questions (Pics)
  44. Possibly the baddest 2nd gen ever
  45. Toytec BJ Lift with New 31's (pictures)
  46. Water by-pass outlet
  47. CANBACK SOFTOP Availible
  48. longest shackles factory springs?
  49. new meats!
  50. 86 toy 4x4
  51. clutch master cylinder
  52. Question for the troubleshooting guru's
  53. Post odo. mileage
  54. Brake Help
  55. brakes
  56. Transmission and Transfer Case
  57. will this work?
  58. 2nd Gen Rear Tire Carrier
  59. Fuel Gauge
  60. Tires
  61. Hi-performance Cat suggestions?
  62. Black Smoke?
  63. HIgh Idle issues (I know I know)
  64. rough Idle after warming up.
  65. gear ratio?
  66. 86 pickup question
  67. engine code 43 (strater signal), what is this?
  68. 2wd body on 4wd frame
  69. my engine quit won't start now
  70. 86 yota 4WD signal light & high speed eng. missing problem
  71. need some flares for my 32x11.5 tyres
  72. 94 Pickup Taillight and Dash short
  73. Royal Purple Max ATF in PS Pump??
  74. Broken Water Pump Bolt
  75. bucket seats
  76. Injuries when working on your truck/4Runner
  77. electrical issues???
  78. Auto tranny is out, manual is in, no start?
  79. idle issue
  80. got some protection!!
  81. 3.0 Valve job
  82. My Yota herd has inreased by one.
  83. Help!! Trouble code 12
  84. prob with throttle/ maybe drivetrain?
  85. driveshaft vibration?
  86. 91 4x4 about to drive me nuts...
  87. what to lift
  88. shift knob for 1994 pickup 2wd
  89. just purchased a 1990 sr5 v6 =)
  90. opinions on 22re.com keith black engines?
  91. Brake light issue.
  92. ARB bumper addition
  93. Gearin on a 3vz V6 help me
  94. Fuel leak..... FIXED!
  95. Weber Conversion
  96. 88' 4WD and 92' 2WD engines the same?
  97. Whats that peice called???
  98. truck has no power cold.
  99. 3.0 Idles great but rough under acceleration
  100. WOAH! headlight problem
  101. locker question
  102. Brake issues-Not the LSPV
  103. shifter probs with body lift
  104. Changing front grill from 93 to 91 4runner
  105. A stutter problem gets worse
  106. tail light problems
  107. Transfer Case Leak, ugh
  108. Possessed 95 4Runner
  109. rear shock valving ?
  110. 1st gen brakes vs 2nd gen brakes 4runner
  111. slow runner
  112. 2.4 l breather
  113. 22re will not start
  114. Breather hoses
  115. can i fit a 1st gen tunel cover on my 2gen runner
  116. 88 4x4 3.0 tran.
  117. 1988 rear seat stuck / broken
  118. oil gauge being wierd
  119. Random Brake Issues
  120. identify these headers
  121. Idler arm solution
  122. Need cat-back exhaust...
  123. 87 Runner HID CONVERSION KIT???
  124. Body straightening or door alignment- 4Runner
  125. Help VIN # location
  126. RPM drops when Headlights are on
  127. Cold Start Question
  128. Back in the Game
  129. Truck not starting. Help!
  130. 94 Toyota with busted 22re, worth $500?
  131. Catalytic Converter
  132. tech question
  133. front end malfuntion need some insight
  134. tranny or transfer case
  135. In need of a Dizzy!!!
  136. Stolen catalytic converter and overheating now
  137. Tranny gear oil?
  138. LOts of pics 3vze rebuild
  139. Igniter?
  140. Land Cruiser Torsion bars
  141. 93 third member on an 86
  142. foward positioning on my SAS with 35's/set axle forward/backspacing recomendations???
  143. Steering issue... strange.
  144. Tailgate - External Spare Tire Compatability
  145. 94 power steering pump repair
  146. start button
  147. What cap with NGK wires?
  148. how important are oil pump dowels in 22re
  149. LSPV - Differences?
  150. Worth the Money?
  151. What is this thing called?
  152. 92 4Runner problems
  153. Finally its getting done!!!
  154. Oil Pan bolt head sheared off
  155. WOO-HOO I passed a Schwanns truck! (but I don't think he had it floored)
  156. sucked water into my 3.4 swap now it runs horrible
  157. Rancho RS 5000
  158. '90 Pickup Clutch issue
  159. how to change tranny fluid?
  160. Power Steering Pulley
  161. temperature sensors
  162. 87 22r turbo question
  163. #5 sparkplug on 3.slow ???
  164. 22re Master Rebuild Kit?!..
  165. 22re Header
  166. new guy with '89 Hilux SURF
  167. Front-passenger ride suspension broken?
  168. Starting Issue
  169. 94 4Runner won't stay running
  170. axle-over lift?/Nice diesel pickup
  171. 4 Runner Power Problem
  172. Dirty, Nasty Head
  173. New member, 2nd gen V6 SR5. Hello!
  174. Front Tow Hooks?
  175. Bad news
  176. front bumper
  177. interior dome light problem
  178. my truck after rebuilt front end
  179. Found 4.88 3rds for my runner thoughts
  180. rattle can paint job
  181. need two tires
  182. need some suspension help
  183. don't hate me
  184. 4:10 or 4:11
  185. Quiz of the day - Crazy idle after header and exhaust install
  186. 22r Cam in 22re
  187. Rhino lining the entire interior
  188. Is this a good deal?
  189. rolled my 86 22re
  190. oil loss???
  191. 4cyl vs 6 cyl
  192. Sometimes it will not start
  193. what the?
  194. Fiber Glass Tailgate?
  195. grille guards
  196. Has anyone done the 22RE-to-V6 conversion?
  197. new here
  198. 22re gas mileage bad...
  199. 22re or 3rz
  200. Ugh. Water in my amsoil...
  201. No 4 wheel high????
  202. truck harness help
  203. Brake System overhaul and they are still not workin
  204. I need a Turbo head asap!
  205. [3VZ-E] Process for removing intake plenum?
  206. 86 pickup troubles
  207. Lift on 90 4runner?
  208. Wheeling prep, vehicle and body
  209. Control arm bracket seperated from rear diff...3rd time
  210. Wheel spacers
  211. hood latch issues
  212. gas saving performance chip???
  213. Starter is clicking....?
  214. Code 26 Lack of power problem
  215. YOTATECH Windshield Banner Giveaway
  216. Cruise control downshifting problem?
  217. New Truck Straightening bed problem PICS!
  218. Front frame bent up?
  219. Starter probs? Totally Confused
  220. well i rolled it, and drove it home
  221. bumper troubles
  222. What Should I Do?
  223. Tinted my windows
  224. Timing chain replacement...
  225. Rotor Rusted to hub? Help!
  226. SAS & swaybar???
  227. I support Yotatech!!!
  228. 86 pickup back fire issue
  229. hub question
  230. what gearing do i get?
  231. 87 pickup hesitates and jerks on deceleration
  232. Do I Buy? 86 4runner with 40s.
  233. I need a Cabin filter
  234. Transmission mystery solved
  235. Pulling bedsides
  236. 3.0 litre fuel pressure regulator
  237. 4L just started working on it's own.
  238. supra afm in 3.0 please help I will do a detailed write up when I get it right
  239. Speedi-sleeve
  240. ordered my tires for the toyota
  241. 80's toyota pickup interior
  242. new motor wont start!!!!!!
  243. Are there any a-pillar brackets for lights out there?
  244. Tie Rod Question
  245. im new to this site toyota problems
  246. 87 toyota clutch problems
  247. New Exhaust install - Pics and Video!!!
  248. Looking at getting a 4runner...
  249. ST2 Gettin some lovin.
  250. woun't drive or run
