Sometimes it will not start
Old Feb 16, 2009 | 09:39 AM
WLR's Avatar
WLR
Help,
I have a 90 SR5 that about every 6 months it will not start (no spark). I will let it sit for a while and try it again a few times and it will start and be good for another few months. This last time it happened while it was running at a stop light. I had it towed home and same as above it is running OK for now. I have replaced the coil, igniter, cap and rotor. Need help with this one.
Thanks
Bill
Old Feb 16, 2009 | 04:05 PM
desert-rat660's Avatar
the vehicle sits for 6 months?
Old Feb 16, 2009 | 05:26 PM
WLR's Avatar
WLR
No I drive it 110 miles total to work every day.
Thx
Bill
Old Feb 16, 2009 | 05:28 PM
4Crawler's Avatar
What are the symptoms of "will not start"? Does the starter turn over or not? If not, see:
- http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
If the start cranks the engine over but it does not start, see:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Feb 16, 2009 | 05:31 PM
ogclew's Avatar
Check the fuses? It happened to me it was the AFM. Air flow meter
Old Feb 16, 2009 | 05:34 PM
WLR's Avatar
WLR
My problem is no spark whem it is in the no start mode. I will check out the other problems you have sent as well.
Thx
Bill
Old Feb 16, 2009 | 05:43 PM
WLR's Avatar
WLR
I looked at the fuses before but I did not check them. I will pull them out and check them out. I think if it was a fuse it would happen all the time. My problem happens after a few months from the last no start cycle.
Thx
Bill
Old Feb 16, 2009 | 05:55 PM
bigt's Avatar
mine did this and it was ignitor/coil!! started random/when damp out.. sputtered and died on day.. had to replace it and truck has been relible as a brand new 22re since!
Old Feb 16, 2009 | 07:13 PM
maybe the pickup coil in the distributor is bad, or getting moisture in it
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
