Need serious help with rear end
Old Feb 21, 2009 | 08:27 PM
Anival755's Avatar
so i have a 94 pickup 2wd with a 22re... its is fully built by LC Engineering and DOA Racing, to where its supposed to produce around 400hp to the wheels... the problem is, im looking to swap my rear end for a bigger and better one.. i have no idea what i should go with though.. any help?
Old Feb 22, 2009 | 06:46 PM
crolison's Avatar
well
What would you think running a 9.5" diff in the rear, like an fj60 rear axle with spring under.
The only problem is its 6 lug where as yours is 5 lug.
Old Feb 22, 2009 | 08:09 PM
tc's Avatar
tc
22re making 400 HP? Sorry, gonna need to see a dyno report on that one.
Easiest to swap in your truck would probably be an 8" out of a 4WD or 1 TON 2WD ... even that would be marginal if you're truly making 400HP, so if you're looking at a custom swap, you could do a Ford 9" or whatever you like.
Old Feb 22, 2009 | 08:25 PM
myyota's Avatar
There is no possible way that you are making 400hp with a 22RE, i don`t care who built it or what they did to it, i doubt very much that its even possible. I had a supercharged ford lightning that made 400hp to the rear wheels and dyno charts to prove it, thats why i say its totally impossible to get 400hp from a 22RE even if it had a turbo or supercharger.
Old Feb 22, 2009 | 08:26 PM
scuba's Avatar
Ford 8.8
Old Feb 23, 2009 | 05:02 AM
crolison's Avatar
I can see 400hp out of a 22re, but it's gonna be so pricey and probably not streetable and built up you could have swapped in a 7m or 2jz for cheaper.
Old Feb 23, 2009 | 07:22 AM
JonnyBoy's Avatar
I would think with 400 ponies you'd be looking at a decently built Ford 9"
There's tons of aftermarket support for 'em, and they're easy to work on, like a Toy 8"
Old Feb 23, 2009 | 07:33 AM
jimep's Avatar
It is hard to get 400 hp out of an re or even rte. I got an rte with a ct 26 turbo, 10 lbs of boost, intercooled, 370 injectors, doa 270 cam, re head w/oversized valves (from engnbldr) and more and i'll be happy if i'm getting 200 or 250 at the wheels with all that.... as for the axle definatly a ford 8.8 out of an 95 to 2000 explorer. it already comes with disk brakes and can be picked up for well under 500 at most scrap yards, at least where I live. 9" rears are way overrated I think. I have a friend at my work running an 8.8 in his mustang that pushes over 800 hp at the wheels on a bad day. (and I'm NOT a mustang or Ford fan)
Old Feb 23, 2009 | 07:47 AM
jimep's Avatar
Oh and one more thing. I don't know if Currie products are junk or what but another friend was running 9 inch front and rear on his heep and was always breaking them. 39.5 X 11's have a way of doing that. He switched the Currie 9" out with a wull width 8.8 out of a f150 and is having alot less problems with that. stick with the 8.8 Explorer cause it has the same lug patern (5x4.5"), is alot cheaper and can easily handlle 400 hp in a small truck with small tires.
Old Feb 23, 2009 | 08:06 AM
Flash319's Avatar
400Hp out of 2 valves per cylinder, don't think so. I say a stock 8inch Toyota will take whatever a 22r will put out.
Old Feb 23, 2009 | 09:20 AM
abecedarian's Avatar
400HP is possible. I'm curious what the torque curve looks like.
from http://www.toysport.com/Technical%20...ech_notes.htm:
... Nitro / Methanol fueled dragsters, producing in excess of 1100 HP- used the original (modified) crankshafts....
Old Feb 23, 2009 | 09:55 AM
Ed H.'s Avatar
This statement makes no sense, your comparing a factory vehicle to a modified engine, although rare i do not doubt this if someone has the cash to do it, it could running on methanol for all you know
Old Feb 23, 2009 | 10:56 AM
Matt16's Avatar
The Toyota 8" will take all those 400 "22RE horsepower's" just fine.
Old Mar 10, 2009 | 05:03 PM
Anival755's Avatar
Post reply
ok i was asking for help, not for people to call me a liar... it is fully built by D.O.A Racing.. It has their long block.. EVERYTHING forged.. LC's Turbo Kit, running 16 psi, Mishimoto front mount intercooler stage 3 fuel system, and an MSD Ignition... i ended up going with a toyota 8 inch... seems to be holding up fine for now...
Old Mar 10, 2009 | 06:51 PM
874runnersr5's Avatar
pics?
Old Mar 10, 2009 | 07:02 PM
Matt16's Avatar
Toyota 8" should work for a while I think, you don't have a particularly heavy truck.
The reason we're skeptical is there are a lot of people who claim their making big horsepower with a K&N filter and 3" exhaust and that simply isn't the case. I don't think anyone on this forum even has a 200hp 22RE (naturally aspirated), so when you say you're making twice that, we're going to be a wee bit skeptical until we see concrete numbers. Also, if you're making 400 at the wheels, then you're making 500fwhp I would think and that number is pretty hard to comprehend (without a dyno) seeing as its coming from an 8 valve 2.4L engine.
I'm not calling you a liar, I'm say show us some proof or we're going to be skeptical.
tc's Avatar
tc
Search on here to get a general feel for people's ..... ummm .... HATRED .... for DOA based on bad experiences.
Put it on a dyno and prove us all wrong!
Old Mar 11, 2009 | 06:37 AM
myyota's Avatar
Show us a dyno sheet and then we will all believe it, until then i still say no way its possible.
icentropy
Sep 16, 2020 02:47 PM
Daneums
Aug 20, 2015 05:36 AM
rondogracing
Jul 14, 2015 07:00 PM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
