Has anyone done the 22RE-to-V6 conversion?
Old Feb 15, 2009 | 08:41 PM
HiLuxer's Avatar
I know it sounds weird. But I have decided to do it. My truck has a strong 22RE with good trans but the frame is too rusty. I found a donor truck, which is a V6 truck but no motor/trans. I'm going to do the swap pretty soon but need some more info on that. I know that the motor mount location is different. Is it too difficult to relocate them? The most of the conversion has been done by the PO (fuel line, pump, rear end, etc.). Is there anything else I need to be aware of? Thanks for all the input guys.
Old Feb 15, 2009 | 08:44 PM
904_runner's Avatar
wait are you going to put the 22re into the truck that originally had the v6?
Im sure someone has done this
Old Feb 15, 2009 | 08:45 PM
vital22re's Avatar
totally a bro
find a 5spd tranny and matching transfer case for the v6 from a v6 and swap in the 3.4 into the v6 truck. Its an awsome swap and i've got the 3.4 in 92 and love it!
Old Feb 15, 2009 | 08:46 PM
HiLuxer's Avatar
Yes, the topic is kinda confusing.
I tried the search engine but not that I could find anything about the motor mount relocation.
Old Feb 15, 2009 | 08:49 PM
HiLuxer's Avatar
I know but I already have a solid 22RE motor w/ the tranny. I just needed a solid truck, which happened to be a motorless V6 truck for cheap. I also don't have a lot of $$ to spend at this time either.
Old Feb 15, 2009 | 08:51 PM
904_runner's Avatar
You will have to fab up the motor mounts, teh crossmember, are both truckst the same type of transmission?
Thats a given, plus all the other hidden problems you encounter.
Old Feb 15, 2009 | 09:28 PM
HiLuxer's Avatar
Yes, they do have 5spd. Thanks for the input. Any link for the motor mounts fab up?
Old Feb 15, 2009 | 09:31 PM
91Toyota's Avatar
Nope never been done. You will clearly be the first ever.
Old Feb 16, 2009 | 05:45 AM
toyminator2000's Avatar
Motor mounts on the v6 truck frame are about 1" farther back than the 4cyl ones so you may need to cut them off and relocate them.
Old Feb 16, 2009 | 06:52 AM
HiLuxer's Avatar
Well, looking forward to... LOL
Old Feb 16, 2009 | 06:53 AM
HiLuxer's Avatar
Thanks. I knew that I would need a good welder for this job since I am not.
Old Feb 16, 2009 | 09:10 AM
mt_goat's Avatar
https://www.yotatech.com/forums/f160...z-swap-126413/
justdifferentials
14
Jun 11, 2017 08:36 PM
live4soccer7
May 11, 2016 06:52 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Gurr
Sep 12, 2015 09:51 PM
