Weber Conversion
Old Feb 19, 2009 | 09:09 AM
hog_hunter_19's Avatar
Weber Conversion
I have an 87 Pick up with a 82 22r. I just switch out stock carb with a Weber 32/36 DGEV I believe I have everything hook up properly. I am having trouble with cranking the truck. If I spray Starting Fluid in the Carb it will crank until it runs out of Starting Fluid. I'm not sure if I need to adjust the choke some how. My first thougt was it wasn't getting any fuel in the bowl. I checked and plenty of gas. Any suggestions. Also how many psi does stock Fuel Pump produce.
Old Feb 19, 2009 | 09:32 AM
abecedarian's Avatar
does the weber have the fuel cut solenoid? if so, is it operating properly?
Old Feb 19, 2009 | 12:57 PM
No Fuel Cut Selonoid.
Pri$erulz
Nov 17, 2019 08:03 PM
live4soccer7
May 11, 2016 06:52 PM
kawazx636
Sep 29, 2015 08:22 AM
runnermedic
13
Sep 21, 2015 05:20 PM
