4 Runner Power Problem
Old Feb 16, 2009 | 10:38 PM
JenkoUS's Avatar
Hi, please help me save my relationship. It's a 1990 4runner V6
The problem is that when I turn the key I get nothing, no engine lights, no radio etc. The hazards and interior lights do work just nothing from the key.
I checked the fuses and I *think* they look fine. The am1 and am2 fuses seem good. I am not sure what the gen 80amp fuse should look like so I am not sure if that is the problem, I researched the part on line and it doesn't look like they do, it seems like to pieces of wire crossed over, they touch but it looks like they only just touch. When I turn the key I do hear some clicks.
I haven't been able to try jump starting as the car is stuck in the garage and I can't see how to get it out.
Here is what happened.
I was replacing brake pads on my g/f's 1990 V6 4 Runner.
I mistakenly took off the front right outer caliper, brake fluid came out, I fixed that, reattaching it, replaced the pads and then bought some brake fluid, filled it to the level, depressed the brake pedal a few times, realized I needed to have power to make it work, turned the ignition on, pressed the brake a bunch of times, turned the engine on, pressed the brake a bunch of times. I may have turned the engine on and off a few times because I wanted to make sure the caliper was secure. Everything looked fine, no leaks etc, got the wheel back on. So I was about about to move the car when I realized I had left the blocks on the rear, turned the engine off, moved the blocks, got back in, turned the key and then nothing.
Last edited by waskillywabbit; Feb 17, 2009 at 03:59 PM. Reason: Pointless links removed...now behave.
Old Feb 17, 2009 | 12:44 AM
Corey's Avatar
Co-Founder/Administrator
What is with all of your links going to the same post?
Old Feb 17, 2009 | 04:08 AM
Zdog's Avatar
Push in clutch?
Old Feb 17, 2009 | 04:52 AM
bigt's Avatar
sounds liek starter contacts
Old Feb 17, 2009 | 06:08 AM
desertcox05's Avatar
if it's an auto put shifter in park or neutral
Old Feb 17, 2009 | 07:21 AM
mt_goat's Avatar
I think this thread borders on spam. Never mind, someone fixed it.
Old Feb 17, 2009 | 07:26 AM
mt_goat's Avatar
X2, that or your battery is too dead to turn it over.
Old Feb 17, 2009 | 04:00 PM
waskillywabbit's Avatar
Original post edited and links removed. This thread is being monitored.
Old Feb 17, 2009 | 04:10 PM
abecedarian's Avatar
how about this:
describe EVERYTHING you did with the brakes... and then, as for jump starting the truck- is the driveway 'uphill' from the garage?
Bamripzit
Jul 19, 2015 01:17 PM
Bamripzit
Jul 13, 2015 07:21 PM
rbravo1
Jun 29, 2015 01:34 PM
renorunnerguy
3.4 Swaps
Jun 28, 2015 09:18 AM
sharrack
Jun 26, 2015 09:33 AM
