hood latch issues
Old Feb 15, 2009 | 10:26 AM
xzyragon's Avatar
hood latch issues
So, after putting my hood on, I realized that it doesn't lock when its all the way down. The thing that you manually push to release works, but the device that is supposed to be released by the switch inside the car does nothing. Here is a picture:
the thing that's welded together works fine, but the latch the hood nob is supposed to go into is not
Old Feb 15, 2009 | 10:32 AM
Tubbyfatty's Avatar
Maybe you have to use a screwdriver and push the "main" latch back? Is the hood going in to the "main" latch or is it just hitting it?
DeathCougar's Avatar
Since you just rebuilt the front of your truck, you are going to have to figure it out on your own. It has something to do with the adjustment of the latch mechanism, and the aftermarket hood you put on. It will take a lot of massaging to fit correctly.
Old Feb 15, 2009 | 10:38 AM
xzyragon's Avatar
thanks....
im trying to bend the mechanism so it doesnt rub atm
Old Feb 15, 2009 | 12:27 PM
xzyragon's Avatar
oiled and bent it and it still doesnt work...
Old Feb 15, 2009 | 12:32 PM
scuba's Avatar
Well there should be a little wire that goes from the inside to that little latch, you need to make sure the ball of the wire is stuck inside the device of the latch...
jasonty
41
Dec 23, 2018 01:00 PM
okamikai
Apr 30, 2018 10:19 PM
raptor510
Feb 17, 2017 07:11 AM
mr_manny
Jul 31, 2015 10:39 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
