Auto tranny is out, manual is in, no start?
Old Feb 19, 2009 | 06:02 PM
91Toyota's Avatar
Got the auto tranny out. Put the manual tranny in, and my truck won't start. I jumped the two wires that tricks the computer into thinking its in park. And still no go. So, what do I look for? Lights come on, so the battery works. Check engine light and all dash lights are lit. I haven't hooked up ANY wires to the manual tranny though. As I can't figure out where the ones from the auto tranny are supposed to go and if I even need them.
So, basically, what should I do?
Thanks
Old Feb 19, 2009 | 06:11 PM
myyota's Avatar
Are you sure you jumped the right plug ?, its a white plug with three conectors on it, and you jump the two that are paralel to each other.
Old Feb 19, 2009 | 06:14 PM
4banginRunner's Avatar
Defiantly a mix up with the NSS
and for the life of me i cant remember which ones to jump off hand right now
Old Feb 19, 2009 | 06:17 PM
881stGenRunner's Avatar
youre supposed to jump the 2 large wires on the large white plug that are right next to each other. did you get those?
Old Feb 19, 2009 | 06:22 PM
91Toyota's Avatar
I jumped the wires on the blue plug. My bad, I'm going to go give it a try in a little while though. Thanks guys!
Old Feb 19, 2009 | 06:24 PM
That should be it then
You don't "need" anymore wires off the 5spd, only things are the reverse lights and the 4wd indicator. Neither of which I have hooked up yet after my swap.
Old Feb 19, 2009 | 07:53 PM
91Toyota's Avatar
lol...its pretty much just a wheeler project anyway, so I'm not worried about that stuff. Thanks!
Old Feb 19, 2009 | 08:41 PM
91Toyota's Avatar
Okay, I jumped those two wires on the big white plug (assuming its the one that goes to the shifter???????????) and still nothing. I jumped the wires on the opposite side too...and still nothing. I ended up blowing an "engine" fuse, and now I don't have a check engine light anymore. So, what do I do?
I can jump the starter from the battery and it will turn over just fine.
Old Feb 19, 2009 | 08:58 PM
myyota's Avatar
Either your not jumping the right wires or something else is wrong, we did the same swap on my 86 4Runner and jumped the wires in the white plug and it fired right up.
Old Feb 19, 2009 | 09:25 PM
91Toyota's Avatar
when you say white plug it makes me all confused. Yeah, I see about 5 white plugs right when I open my door. I can't tell you what is wrong. I thought it would be simple.
I jumped this "white" plug...5 wires
This "blue" plug 4 wires
There are lots of plugs.
Old Feb 19, 2009 | 09:28 PM
91Toyota's Avatar
But, as I can see now, that white plug doesn't have a damn thing to do with anything. LOL
Old Feb 20, 2009 | 05:54 AM
The plugs that need to be jumped are located in the passenger side wheel well, around the fuel filter/starter area. Should be a cluster of 4-5 of them if i remember correctly, and the larger round white plug with larger wires than the rest was the one...not 100% on that, trying to think back a few months lol
Old Feb 20, 2009 | 06:15 AM
myyota's Avatar
The plug you need to jump is around the starter/fuel filter area, its a round white plug. the plugs under the dash won`t do anything and are now no longer needed with the manual transmission, just tuck them up under the dash and forget about them.
Old Feb 20, 2009 | 06:39 AM
91Toyota's Avatar
Well basically I'm a tard
I've been jumping the wrong wires the whole time. And you said it has 3 wires and I jump the bigger of the two correct?
Also, Do I cut the wires before the connector or after? Probably doesn't matter though.
Thanks guy! Yotatech is awesome!
Old Feb 20, 2009 | 07:52 AM
Don't cut the plug if you don't have to, and you don't. Just make a simple jumper wire (about a 4" piece of wire with 2 spade terminal ends on it). Plug it in to the plug, and wrap it in electrical tape or something of the sort to protect it from the elements and from being unplugged.
Old Feb 20, 2009 | 01:22 PM
91Toyota's Avatar
The truck LIVES!!! haha, I'm so excited. Now I just need to put my new pedals in, clutch master cylinder, and the lines and I'm ready to drive! yay!
I'm so freakin excited!
91Toyota's Avatar
Oh yeah, and I'm going wheelin' if I get it running by tonight, and I'll go wheeling tomorrow
Old Feb 20, 2009 | 01:23 PM
91Toyota's Avatar
No more 2wd wheeling!!!!!!!!!!!!!!!
Old Feb 20, 2009 | 01:26 PM
scuba's Avatar
Yay haha !!
Old Feb 20, 2009 | 01:27 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Congrats on the swap, '91!
