#5 sparkplug on 3.slow ???
Old Feb 17, 2009 | 08:58 AM
tktmsa's Avatar
OK, there is probably posts buried deep within the forum....anyone have a link or tricks to get at this plug (rear passenger side) got them all done but this one.
Old Feb 17, 2009 | 09:31 AM
redvette's Avatar
two 6 inch extentions an c/v joint or whatever its called. itll go
Old Feb 17, 2009 | 10:05 AM
tktmsa's Avatar
got a lot of extensions and cv, can't get the current wire pulled, do I have remove hoses/other junk to get a grip on it?
Old Feb 17, 2009 | 10:11 AM
Jay351's Avatar
Its tight, but doable.
Long extension and a wobble adapter. To re-install use a peice of rubber hose just big enough to slip over the end of the plug. This way you will have a harder time crossthreading it. (an old mech did that to my number 6 plug).
What plugs are you using (gapped to 0.030" right?)
Old Feb 17, 2009 | 10:42 AM
tktmsa's Avatar
NGK's with anti-seize gaped to .032.
Gotta say the old plugs have been a bear to get free. Went slow kept even pressure.
I guess I have big mitts/arms cause I can't get a decent grip on #5 to pull the wire. I'll take a break from it and revisit it later
Old Feb 17, 2009 | 11:29 AM
TNRabbit's Avatar
You need one of the wire pullers....you can probably fake it with long handled bent-needle nose pliers.
Old Feb 17, 2009 | 12:26 PM
turborich's Avatar
I don't see what is so hard about this? I changed my plugs on the 3.0 for the first time & it only took me about 15-20 minutes. I used a 1/2 drive ratchet along with a 3" & 6" extension & a wobble. It was very easy & straight forward. The piece of hose will help you to get them back in as that was the only tricky part.
Old Feb 17, 2009 | 03:11 PM
tktmsa's Avatar
Ya'll gots little hands
Old Feb 17, 2009 | 04:02 PM
Jay351's Avatar
I got big hands.. they are telented though
39 Thieves
Jan 6, 2017 01:08 PM
Yotav6power
16
Mar 4, 2016 07:45 AM
shooter86314
Jan 7, 2016 07:05 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
mad_sb
Aug 28, 2015 01:21 PM
