86 pickup troubles
Old Feb 15, 2009 | 01:58 PM
wwwcpefc's Avatar
86 pickup troubles
Hey to all
I found this site while doing a sreach for a problem i am having with a 86 22re pickup. I have done a bit of sreaches on this site on my problem but no luck so far. So posting comes next. here is what i am working with.
86 re 2200
had sat from 02-08
replaced plugs,wires,cap,button,coil, and fuel pump,oil,filter,air filter clean.
after that she cranked and run fine.
one day while in a hurry it skiped alittle
now it runs fine until the motor warms up 10-15 miles
then under a load or not if you push it over 2100 rpms it will die like you cut off the switch.
under 2100 runs fine.
push in the clucth revs to 4500
idles high when cold gets a little rough when hot.
also dont think the fuel cap is the ome one if that could cause problems. when you remove the cap it hisses.
looking for somewhere to start on this thing. It is a good old and enjoy it but 30 mph anit cutting.
thanks for the help in advance.
Old Feb 15, 2009 | 02:13 PM
toyota4x4907's Avatar
The hissing is normal. Its just the pressure releasing from the fuel line.
I don't know about your other problems.
Old Feb 15, 2009 | 02:22 PM
Dirt Master80's Avatar
problems
U have a hard to solve problem. I would be looking at electronics, it doesnt sound like a mechanical problem
Old Feb 15, 2009 | 03:27 PM
abecedarian's Avatar
First off...
It's a 22RE, ~2400 cc's, not 2200.
Some hissing when removing the gas cap is to be expected, particularly when temps swing from cold to hot. At worse, the EVAP canister is not being purged properly.
Cold idle should be high- depending on ambient temp could be as high as 1500 rpms. Warm engine idle is the important thing: should be 750, give or take 50.
Now... are you getting any trouble codes?
Old Feb 15, 2009 | 03:36 PM
Fofo's Avatar
Sounds like a fuel problem. Im thinking u might have a plugged injector
Old Feb 15, 2009 | 05:14 PM
wwwcpefc's Avatar
as for the codes i have not had them checked yet, but i am.
thanks to all of yall for the info.
Old Feb 16, 2009 | 07:51 AM
Wile E. Toyote's Avatar
Codes are very easy to check and will help you troubleshoot a great deal. With the symptoms you described and no codes, it's a stab in the dark.
Old Feb 16, 2009 | 08:04 AM
muddpigg's Avatar
Check vacuum lines and egr
mskalmus
May 28, 2017 07:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
cyclist231
Jul 7, 2015 12:56 PM
elwood73
Jul 5, 2015 07:07 AM
