92 4Runner problems
Old Feb 17, 2009 | 03:14 PM
Dusty19's Avatar
92 4Runner problems
so the other day i was driving down the road and hit a small bump and for a split second my 4runner shut off and all the dash lights came on. I'm trying to narrow down the possibilities of what it could be and I think it might be a fuse wire somewhere in my truck, not sure though. Anyone with a better idea please reply.
Old Feb 17, 2009 | 03:17 PM
abecedarian's Avatar
battery + lead to the fuse block under the hood.
loose ground.
Old Feb 17, 2009 | 03:22 PM
Dusty19's Avatar
ok thanx, thats what i was also thinking because my positive clamp going to my battery is bad and doesn't clamp tight, so im going to get a new post clamp and tighten the ground wire to my fuse box
Old Feb 17, 2009 | 03:29 PM
and don't use engine grease on the clamps. engine grease is an insulator- it does prevent corrosion but....
if you have to have something, use noalox or kopperkote, or most any anti-sieze compound.
Old Feb 17, 2009 | 03:32 PM
desert-rat660's Avatar
also do a wiggle test on the wiring harness, if the above doesnt cure the problem
Yota.Jay
Jul 23, 2015 08:08 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
