prob with throttle/ maybe drivetrain?
Old Feb 19, 2009 | 04:24 PM
Ol'Lee's Avatar
i have a problem when im cruising about 20 to 30 miles an hour in traffic, it feels like im letting off the throttle then getting back on it and i have to accelerate faster than that or have to push in the clutch to get it to stop? and also when im on the highway and i let off the throttle it dosent just slowly drop rpms it feels like a strong lurch? im lost ive checked for vacuum leaks couldnt find any and maybe thought my throttle cable was to loose but adjusted that and no change? maybe something in the drive train like universals going out? help thanks
Old Feb 19, 2009 | 04:50 PM
jessekosten's Avatar
Have you regeared you truck to match the tires? And what gear are you in?
your tps could be failing.
Old Feb 19, 2009 | 05:04 PM
waskillywabbit's Avatar
Sounds like your TPS.
Old Feb 19, 2009 | 05:07 PM
abecedarian's Avatar
+2
IF the TPS is registering IDL to the ECU even when the throttle is opened a little bit, this could happen.
Old Feb 19, 2009 | 05:29 PM
Ol'Lee's Avatar
would that throw a check engine light if it is going out? if not can i just check with a ohm meter? or is it adjustable? thanks
Old Feb 19, 2009 | 05:30 PM
Mine didn't. Yes, there is a procedure for checking outlined in the FSM...several links here online in various threads. One is even stickied about FSMs.
Old Feb 19, 2009 | 05:31 PM
TPS check: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Feb 19, 2009 | 05:41 PM
Ol'Lee's Avatar
thanks guys
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
TheBFA
Feb 15, 2020 06:55 AM
bryan34w
12
Sep 30, 2015 02:50 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
sonorn67
Sep 19, 2015 05:39 PM
