4:10 or 4:11
Old Feb 16, 2009 | 02:18 PM
regularjoe's Avatar
4:10 or 4:11
I wanted to know if Toyota made a 4:11 gear ratio. I searched for a while and found some info they did. I also see things on sale in the classifieds with 4:11 ratio. I cant find a axle code on my 87. I looked all over I may be missing it.
Long story short I bought a 87 x cab truck on a 4runner frame and running gear. I recived the axles, tranny, and transfer case from the truck for spares and just wanted to make sure they didnt offer a 4:10 and 4:11 gear ratio i 87. Could someone please clear this up for me the search just made things more confusing I tried.
Thanks,
Jason
Old Feb 16, 2009 | 02:26 PM
89silverpu's Avatar
They did make 4.11's, but I'm pretty sure that was only in the earlier 80's years. Even if you did mix 4.10's with 4.11's I don't think its even a big enough difference to be a problem, .01. Someone please correct me if I'm wrong!
Old Feb 16, 2009 | 02:29 PM
89silverpu's Avatar
They switched to the 4.10 ratio in 84 so your 87's will both have 4.10's. Just took a quick Google search.
Old Feb 16, 2009 | 02:38 PM
regularjoe's Avatar
Thanks for the quick reply. I never thought to google search it. I just did the search on here.
Old Feb 16, 2009 | 02:40 PM
89silverpu's Avatar
No problem!
Old Feb 16, 2009 | 02:48 PM
JasonWin's Avatar
It might not be a big difference in 2WD, but if you had one diff at 4.10, and one at 4.11 in 4WD it'd cause problems.
Old Feb 16, 2009 | 03:24 PM
crolison's Avatar
nope, its within the allowable percentage difference to run. Thats how guys run 5.38's and 5.29's in the same rig. Offroad your not going to be running high traction surfaces and are allowed a little bit of give on ratio's so they are fine.
Old Feb 16, 2009 | 03:43 PM
89silverpu's Avatar
Yeah for example when people put a Dana in the front and can't find a matching gear for the Dana and 8 inch sometimes they're off by just a little bit.
Old Feb 16, 2009 | 03:44 PM
89silverpu's Avatar
If you had a 4.56 and a 4.10, or a 4.56 and 4.88 or a similar difference, that's when you start getting into problems.
Old Feb 16, 2009 | 03:51 PM
OutlawMike's Avatar
I ran 4.10's in the rear and 4.11's in the front of an old 1/2 ton chevy I used to own. Never noticed a thing.
4.10 is 10 on the pinion, 41 on the ring for 4.10
4.11 is 9 on the pinion and 37 on the ring for 4.1111111111.....
You will not have any issue running a mixed set.
Old Feb 16, 2009 | 03:57 PM
tc's Avatar
tc
4.11 is probably quite a bit stronger though
The 4.10 you're getting some pretty damn small teeth on the ring gear ...
Old Feb 16, 2009 | 04:09 PM
89silverpu's Avatar
True, but 4.10's are still very strong. You could debate this just like people argue that 5.71 gears are weak because they are thin or whatever.
Old Feb 16, 2009 | 05:20 PM
regularjoe's Avatar
Thanks for all the help.
Rickstwowheels
Sep 18, 2015 03:48 AM
darbtaco11
Jun 5, 2009 06:45 PM
b1gmoose
Jan 29, 2008 05:41 AM
