how to change tranny fluid?
Old Feb 17, 2009 | 12:53 PM
cEElint's Avatar
alrighty.. its about that time to change the transmission fluid i believe.. not really sure how to do it though.. haha.. so of course i need a little direction here.. also, when replacing the fluid.. what fluid do i use? can i use a synchromesh.. i think i may need it.. my gears feel kinda mushy when shifting
91 Toyota 5speed 22r-e
Old Feb 17, 2009 | 01:04 PM
rdlsz24's Avatar
Before draining out the old fluid make sure you can break the fill bolt on the driver's side loose. Nothing worse than having an empty transmission and no way to put fluid back in it lol. Refill with gear oil.
Rob
Old Feb 17, 2009 | 01:14 PM
claudebadly's Avatar
find fill plug, make sure you can take that off BEFORE you drain the fluid, cuz if you cant fill it then you are HOSED. fill the tranny with about 3.2ish quarts of 75W90 gear lube *can usually get at Napa or CarQuest, what ever your preference is.
as far as where the fill and drain plugs are.... idk, someone is bound to tell you later lol
good luck man
Old Feb 17, 2009 | 01:24 PM
littlecommando's Avatar
sorry for the thread jack, but is this something that the average person can do without help?
cause im not sure if mine has ever been changed...
Old Feb 17, 2009 | 01:28 PM
4Crawler's Avatar
Typically yes, no different than changing engine oil. No filter needed, just fluid and usually an in-bottle pump to get the fluid into the filler hole:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#Fluids
Old Feb 17, 2009 | 01:39 PM
OH!! and dont forget the impact with a 24mm 6 point
cuz a breaker bar WILL strip out the head and now i get to have fun with a hammer, chissle, vise grips, and a 24 pack lol
Old Feb 17, 2009 | 01:49 PM
Jay351's Avatar
Uhm. No! Don't use an impact on those bolts! they don't hold the friggen truck together.
cEElint's Avatar
yea.. i'm aware of the fill plug thing... i made the mistake of draining the fluid in my Honda first so it created a vacuum on my fill plug.. was a pita to get out
so 3.2 qrts of 75W90 .. do they sell a synchromesh in that weight? and yea.. a little direction as to where the drain and fill plugs are..
Old Feb 17, 2009 | 01:57 PM
cEElint's Avatar
would a synchromesh even work in this tranny?? would the regular tranny fluid get rid of the mushiness of the gears
Old Feb 17, 2009 | 02:00 PM
4Crawler's Avatar
It is a syncromesh transmission, so as long as the oil is GL-4 rated, it will work fine, I like Redline MT-90 in mine:
- http://www.4crawler.com/4x4/index.sh...ntheticGearOil
Old Feb 17, 2009 | 02:15 PM
cEElint's Avatar
thanks a lot... now where do i find the drain/fill plugs? .. hah
Old Feb 17, 2009 | 03:30 PM
874runnersr5's Avatar
drain plug is right underneath the tranny..
the fill one is on the drivers side kinda on the upper left hand area no?
you can just fill it from the top, take out you shifter stick, and you can fill it from there i belive
Old Feb 17, 2009 | 05:08 PM
cEElint's Avatar
thanks for the reply.. when i get a chance i'll go outside and check it out.. should be too hard to find
Old Feb 17, 2009 | 05:11 PM
yeah, the factory service manual has it in there somewhere, you can refer to that to
smthwsn357
May 1, 2024 07:28 AM
Up&Down
Aug 11, 2015 10:04 AM
yourrealdad
Jul 21, 2015 11:13 AM
madxman21
Jul 9, 2015 10:26 AM
