PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Rear window won't go up/down? Try this first.
  2. 1986 Clicking clunking only in 2 wheel drive
  3. 86 22re 4x4 headache
  4. How important are perfect idle TPS readings?
  5. 1990 22re pickup 2wd coolant bypass hose
  6. Head Gasket Set
  7. Hey coilovers guys. Got a ?
  8. what year is my engine
  9. Greasing the IFS steering knuckle?
  10. Headlight time...again....H4 conversion
  11. Can't set TDC. Head gasket 22r
  12. Steering column wire
  13. G58 to W56c swap wiring help
  14. oem bolt and screw part number
  15. Anyone know is there is a 1600lb clutch set up for a 94 22re?
  16. crank shaft pulley bolt
  17. Ignition Switch missing
  18. Now there's a new problem
  19. 94 toyota pickup catalytic converter bolts
  20. First Generation 4Runner Roof Rack - Yakima Side Loader
  21. 22re not getting fuel
  22. idle problems
  23. 2JZ Swap Questions
  24. Power steering pump pressure switch
  25. Replace shifter bushing
  26. 4Runner values
  27. Arb seal housing
  28. What calipers does my stock 92 Pickup have? 17s or F18Q?
  29. Some kinda electrical issue
  30. 1994 Pickup 4x4 v6- 3.73 gears swap?
  31. 1994 pickup start/idle problems
  32. Need help removing fuel pressure regulator
  33. 88 22re starts then shuts off.
  34. newbie, please help, 87 22re no start
  35. Swapping Transfer Case Help
  36. 87 starts, but dies after a few seconds
  37. Works for a While, Then Shuts Down
  38. 86 22r idle, and mpg issue.
  39. Wiring Harness Question - Manual vs Auto
  40. 3.0 actually Delco pf 57?
  41. Newbie (Sorta) needing a little help.
  42. Rear wiper switch re-purpose
  43. Need to diagnose my 93 pickup
  44. 1990 22re starting problem
  45. Crunch time !! Sickening
  46. 22re Radiator/coolant/reservoir question
  47. No brights
  48. 1992 new rear leaf springs still flat??
  49. No power to coil any ideas
  50. I'm retrofitting a factory tire swing onto my 4runner over Xmas break...follow along!
  51. 1989 truck will not start
  52. Valve closest to my oil cap
  53. coolant question
  54. Camshaft won't rotate after reinstallation
  55. 93 4x4 pickup 22re Blown head gasket??
  56. runner runnimng poorly after eng swap
  57. Spark but no fuel
  58. Wiper motor replacement
  59. Camper shell for 94 pickup
  60. Weather Stripping
  61. Different size distributor caps?
  62. Power steering leak
  63. 1990 22re alternator adjustment bolt the one on top
  64. Did 2nd gens have a headlight warning buzzer? Might need some electical help...
  65. Radiator cracked! new one?
  66. J.z.
  67. Injectors clogged with rust and sediment. What next?
  68. Manual Transmission Oil
  69. tire rub
  70. 22r sputter with "new carb"
  71. factory installed lockers???
  72. Torsion bar identification
  73. Carb model question- 35291
  74. 1986 pickup 22-R FSM
  75. 86 22ret issues
  76. 91 4runner winch mounting
  77. Camper top for 1990 pickup
  78. engine swap advice
  79. Rolled 22re only cranks over without plug
  80. 22RE Code Issue
  81. 1990 speedometer cable
  82. Replacing timing chain guides on 22r and removing intake manifold gasket
  83. Took my bench seat out
  84. New to the IFS world. What should I expect?
  85. Noise after replaceing timing chain, water pump, and oil pump.
  86. New to me 4Runner need advice
  87. Lil Help
  88. Need some advice....
  89. Need some advice...
  90. Speedometer Cable Help - 88 pickup 4x4
  91. Decent seat covers for a 2nd generation
  92. Need help finding a replacement fuel strainer
  93. 87 4Runner rear window issue
  94. Keeping the fuel door closed suggestions?
  95. Question about code 25 toyota pickup 3VZ-E
  96. starts but wont stay running. out of ideas! 87 4runner @@re
  97. Time to change my fluids!! help
  98. Having to press gas in order to start 22RE
  99. Is my Air flow sensor done?
  100. '86 22r timing help
  101. Adding heat to stock SR5 seats?
  102. WEBER 32/36: high idle and a bunch of other BS
  103. Intake: Engine Dies When Air Cleaner Box is Opened
  104. Popping out of third gear
  105. 3.4L from unknown donor
  106. Where to find Cold Start Time Switch? Aftermarket Alternative??
  107. intake manifold bolt size 3vze
  108. High Idle and Burnt Coolant - 1989 3vze
  109. Curious about ac system
  110. Knock sensor interchangeability?
  111. A340H a/t transmission constantly shifting
  112. Where can I find a 22rte injector
  113. Headlights go out on an 88 22re
  114. 1992 pickup 22re - rattle at cold start
  115. 91 4 runner dreaded 3.0l
  116. '87 4Runner, questions about newly installed transmission
  117. Silicon Coolant Hoses - Any Experiences
  118. 3vze 3.0 camshaft
  119. Bad Time Switch - Can I ground Cold Start Injector?
  120. Floor mats on a 1987 pickup. Drill into the floor?
  121. Issues with coolant routing.
  122. Alternator Regulator Testing Off vehicle
  123. Failed Head Gasket Repair
  124. Vacuum advance w/ a Weber carb.
  125. Pulled intake manifold to connect knock sensor, running horrible now
  126. [Q]Determine lift and shocks
  127. The Never Ending Speedometer Noise Story, or is it....
  128. Speedo Replacement
  129. Worth the buy?
  130. Need shock part numbers
  131. De-Monster Trucking my 1987
  132. '90 22RE Pickup Chugging and dieing off the line
  133. Where to find sensor wire connectors
  134. 93 3.0 4x4 Loses Electrical Briefly
  135. Transmission problems.
  136. 3.0 3VZE Throttle Position Sensor + Transmission
  137. Engine Questions R22?
  138. Oil leak
  139. Advice on pulling a 3.0 engine
  140. Continue to Reapir Problematic 22RE Alternator?
  141. Disconnecting Fuel Line between filter and Injectors
  142. Cold Start injectors
  143. 1990 4Runner Fuel Filter Location!
  144. Tracking down a power steering leak in '91 V6 3.0
  145. Function of orange / black check valve on 3VZE manifold?
  146. Noisy valves causing CEL Code 52?
  147. Oil in the bell housing... again.
  148. Head gasket ? Opinions needed
  149. 1992 3.0
  150. Anyone have a tailgate access cover???
  151. The New 3VZ-E Timing Belt Replacement With Pics Thread
  152. Replacing wheel studs
  153. 1993 4x4 22RE Help
  154. Fuel pump issue
  155. 3 small alternator wires
  156. 1986 22RE 4x4 SR5 o2 sensor location
  157. CAD Engine Mount Files
  158. Help to diagnose starter charge issue
  159. This clutch is driving me crazy. Please help
  160. Opinion needed
  161. Rebuilt 5vz-fe Break-in
  162. New Guy with Inherited 86 Pickup
  163. 3VZE No Spark. Big Mystery
  164. 22re engine rebuild????
  165. A yota tale with a few questions remaining
  166. Weber 38 87 Hilux
  167. Clunking in reverse, whirling in 5th
  168. Max wheel offset for toy axles
  169. Blower motor relay
  170. 22re with a Carb
  171. Seized cylinder
  172. Timing jumped 22 degrees after atune up
  173. Headlights and tail lights problemzzz
  174. Replace #2 idler pulley
  175. De-smogging 22r: intake manifold plugs?
  176. De-smogging 22r: are water block-off plates necessary?
  177. 1990 3.0L Knock Sensor Plug Identification
  178. Unknown Port or Connector on 91 4Runner. Help?
  179. Need Climate control assembly
  180. 22r gutless uphill?
  181. Slow Truck Rebuild
  182. 22rte rough start and weird noise when cold
  183. 1992 2wd truck 22re ce lite trouble
  184. Transmission swap - connector on transmission 1989 4 runner
  185. 3.0 Exhaust
  186. 3vze rebuild or fix only damaged cylinder
  187. Selling a Toyota pickup
  188. Peeling film on new 3.0 headgaskets
  189. Fuel inside Vaucuum Hoses
  190. Carrier bearing/ u joint?
  191. Shifter Adjustment, 1990 4Runner, VZ/Auto
  192. Alternator Upgrade: Need New Wiring?
  193. Questions about Bed Size
  194. factory rear drums/back plates variations
  195. Yotalockers.com - Elockers for Pick Ups and 4Runners
  196. ECM connector with a loose/bad wire
  197. Fuel Filter change 3.0 with injectors ?
  198. How do I test the back window relay on a 2nd gen?
  199. 22re no power at key
  200. Windshield area leak
  201. 1986 22re 4x4 runs great cold, then gets warm and runs awful...
  202. 3vze Head gasket
  203. Got the Windshield Out
  204. 3.0 power steering problem. I think?
  205. Can anyone tell me what this connector is to?
  206. 89 3VZE Flat spot/bog/flooding when cold
  207. Hi guys! Long time :) Upper Ball Joint Question
  208. Thermostat and Shift Issues 1986
  209. Error code 24
  210. 95 4runner lifted 4" - BANGS into reverse and first
  211. Hard to start rebuilt 22re
  212. Fuel pump
  213. Good sources for new 2wd leaf springs? Problems removing spring from pack?
  214. Good And Bad News
  215. 22re electrical connector question
  216. W56 Transmission Woes - TOB and ID
  217. 1st gen rear brake shoe part
  218. 88 4runner 33x12.5x15 rubbing
  219. Door lock cylinders 93 PU
  220. Bad transmission: Best options for replacing?
  221. 22re Fuel injectors
  222. spongy brakes
  223. 3.0 sounding like a sewing machine
  224. Rocker arm slack
  225. 90 4Runner 3.0 v6 no rev limiter
  226. 90 4Runner 3.0 v6
  227. EFI fuse blowing after sparkplug wire disconnect
  228. Clutch to the floor
  229. 92 PU w/22RE no idle when warm
  230. 1988 4Runner - I think I messed up
  231. What is the REAL way to check ball joints on IFS 4Runner/Pickup
  232. Blazeland pics
  233. Parts list for Weber 32/36 conversion? Preferred fuel pressure regulator and intake a
  234. How to diagnose dimmer switch?
  235. 2nd gen 4runner power mirror switch
  236. In need of shifter trim piece.
  237. W56 Transmission Storage Cases?
  238. code 25 93 4runner
  239. Heater Duct Hose????
  240. Desperate help! 22re not running!
  241. Motor oil instead of Antifreeze??
  242. Starting issue
  243. 1989 Toyota pickup throttle position sensor help!!!
  244. 86 4Runner speedo off?
  245. Oil leak on 94 toyota pickup
  246. 85 4Runner: Help me name this part?
  247. determining if I have a blown head gasket or timing chain 86 22r
  248. transfer case CF loose
  249. HELP! Huge oil leak passenger side 3vze
  250. How many amps does a stock SR5 need to run
