transfer case CF loose
Old Nov 16, 2016 | 07:20 AM
the171's Avatar
Hey guys. Ive been trying to find the source of a slight vibration in my 93 22re 5spd 4x4. Truck has new tires and runs really good. Upon greasing the u joints I noticed there is some play at the transfer case companion flange. It seems to be the flange which is loose rather than the u joint. What to do about this?? Its hard to tell from the video. Towards then end its better. But I can feel and see movement.
Old Nov 16, 2016 | 07:42 AM
millball's Avatar
They loosen up over time and miles.
Here is a thread that deals with this:
https://www.yotatech.com/forums/f116...-tight-297255/
Old Nov 16, 2016 | 08:01 AM
osv's Avatar
osv
can you be specific about the nature of the play you are seeing? is it rotational slop, or side-to-side slop? the video is useless, trying testing it by grabbing the u-joint, not past the slip joint.
Old Nov 18, 2016 | 04:46 AM
the171's Avatar
The play was at the flange. I tightened up the 30mm nut with a breaker bar. The nut turned only a small amount. But this removed most of the play. Now there is only a very small click. The vibration I was experiencing seems gone.
hopefully this will work another few years. I'd like to avoid a transfer case rebuild.
Old Nov 18, 2016 | 10:46 AM
osv's Avatar
osv
thx for posting how it worked, sounds like what millball has been describing.
what i also did was compare the free play to how much free play there was the front transfer case output.
