'86 22r timing help
Old Dec 15, 2016 | 05:47 AM
ztrain13's Avatar
'86 22r timing help
I've got a 22r with an aggressive race ported head and intake, mid range cam, Weber 38 carb, MSD 6AL ignition, and blaster 2 coil. The carb has been installed but not been touched also I'm running 2.75 psi for fuel pressure with all emissions removed. The pickup has no trouble accelerating up to 3k rpm but after that seems to struggle. I've got the base timing set at 8 degrees.
Old Dec 16, 2016 | 09:06 AM
ztrain13's Avatar
Bump^
