Headlights and tail lights problemzzz
Old Nov 30, 2016 | 10:47 AM
Franck1970's Avatar
Exclamation Headlights and tail lights problemzzz
Hi,
I am looking for some help...
After a ride under rain and snow, my 1992 pickup have nice problems :
Brake lights don't work
Numeric clock is dead
Headlights stay open when I shut the motor off and remove the key from the contact switch. Sometimes, after few minutes, lights are finally closing!
When I set the key to ACCESORIES, the headlights are turning off and when I start the motor everything is fine.
Also, when the vehicule is shut off, if I press brake pedal, the dash lights open.
What should I look first? The truck is in a warm place since 2 days and I try to see if the is no water around ou inside the fuse boxes... nothing fixed yet.
Thanks
Franck
Old Nov 30, 2016 | 02:08 PM
wyoming9's Avatar
Just what are you working on that has Rotating Headlights??
What kind of 92 Pick up?
Old Nov 30, 2016 | 02:41 PM
scope103's Avatar
My guess is "English as a Second Language." Heaven knows I can't do as well as Franck1970 when I try to post to Russian forums.
So, Franck1970, welcome to Yotatech!
As you've suggested, you have a large number of problems without much in common. I would start by looking for any water near either junction/fuse box: next to the driver's left ankle, and one under the hood on the right side.
Old Dec 1, 2016 | 07:00 AM
Franck1970's Avatar
Hi and thanks for your fast replies...
In fact I'm from Quebec, Canada. Almost the same climate as in Russia
We found the problem: it was under the lining of the front left fender. A bad move with the buffer when rebuilding floors (metal sheet + fiberglass) scratched a bit of a nice little RED wire.
Everything's fine now.
BTW it's a 1992 xcab 4x4 with a full rebuilt 22re.
I'm going right now to buy a lottery ticket... Heaven knows...
Thanks a lot and have a nice ride!
Old Dec 1, 2016 | 03:10 PM
ROSSI357's Avatar
Hey gang ..am new here but i had a problem with my dash lights and tail lights not working. I tried everything. Turned out to be the relay switch which is located on the fuse box. Give this a shot if you have the same problem.
Old Dec 2, 2016 | 05:20 AM
Franck1970's Avatar
Hi,
Had similar problem with my dash last winter. It was just that all bulbs in the dash were burned-out. When the last one died, I thought about an electric problem...
Cheers
