A340H a/t transmission constantly shifting
Old Dec 12, 2016 | 03:54 PM
theianmcdougall's Avatar
1995 4x4 automatic 3.0L
Recently it got pretty cold where I live. And my trans started shifting constantly when I'm light on the throttle.
It still will make it through all the gears if i give it a good bit of gas, also has plenty fluid.
Could it be the solenoid? I hear thats a pretty common problem.
Any help would be awesome.
Old Dec 12, 2016 | 03:58 PM
Trents3.slow's Avatar
I'm pretty sure these have a kickdown cable that can be adjusted.
Old Dec 12, 2016 | 04:31 PM
scope103's Avatar
First, check for codes: http://web.archive.org/web/201408161...31diagnosi.pdf
More likely, you have a problem with your ECT sensor.
Old Dec 12, 2016 | 04:50 PM
Only code im showing is 71 (EGR)
How do i adjust the kickdown cable? Where is it located?
Im used to working on manuals so this is all new to me.
Old Dec 12, 2016 | 04:51 PM
And what would a ECT sensor have to do with it. Isnt that a coolant sensor?
Old Dec 12, 2016 | 05:19 PM
scope103's Avatar
The codes for the transmission are read differently than the Check Engine codes. But I'm sure you did it correctly.
Primarily, when the engine is cold, the ECM will not engage the lockout clutch in some gears, or shift into overdrive. While your symptoms aren't the usual, the connection to cold suggests an issue with something that SENSES the cold.
Just so you know, you don't have a "kickdown" cable. The shifting is all controlled by the ECM, based on various inputs, including the Throttle position.
But you do have a "throttle" cable. http://web.archive.org/web/201408160...32prelimin.pdf It doesn't control WHEN the transmission shifts, but rather how hard it shifts (harder at greater throttle opening). Never hurts to check the adjustment, though.
Old Dec 13, 2016 | 10:19 AM
I read somewhere Throttle Position Sensor could have something to do with it, they are really cheap so i ordered one. Hope that fixes it.
Old Dec 15, 2016 | 02:45 AM
maco35's Avatar
You were supposed to test it before replacing the TPS and adjust it in case it was out of adjustment. http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Dec 15, 2016 | 06:02 AM
Those things don't just fall out of adjustment when the truck has been running fine for months. Plus it wouldn't cause my trans to shift eradically. My guess is the sensor is defective throwing random voltages and the TCM sees that as me constantly punching the gas and letting off. Plus TPS sensors are $11 on eBay. Hope it works
